Question about Acer Aspire 5610-4648 Notebook
No boot, screen blank after hibernation
Brand new laptop, first time placed manually in hibernation, now will not boot. Have attempted power recovery and battery charge. Indicator lights appear to work appropriately. both are green. screen has remained blank since hibernation was induced. have checked brightness and toggled f5 and could find no sleep indicator light.
  • Anonymous Feb 05, 2008
    Same problem with Acer Travelmate 3043
    I've taken out one memory, and then it let me start it properly, by giving me the message that the memory has been changed and Hibernate will have to be deleted.
    At least it worked in the end.
    It appears to be a Microsoft problem mainly.
    this article
    provides some good links with hotfixes.
Sounds like a memory issue for sure! but I also know that when you put a laptop into hibernation mode it uses about 400MB space for special quick start up access. I think that you may want to try to repair your installation of Windows, you would havw to put your restore disk in and instead of re-installing the OS just repair it...
Posted on Feb 19, 2008
  • 383 Answers
NTLDR is missing Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in.
Getting into Windows Safe Mode Users who may not be able to boot into normal mode or are not able to .... This is the most basic Safe Mode option and has no additional support.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 26, 2007
My HP Compaq 6735s.I got it as a present from my
You have lost the operating system on the hard drive, try putting a recovery cd in to the drive and see if it will boot.
If not try a Linux boot system recovery disk, downloadable off the internet, to see if you can repair it.
Sep 24, 2014 | Computers & Internet
Dropped laptop while in hibernation mode
sounds like your luck may have run out
dropping a laptop would usually cause a hard drive head crash, and that sounds exactly what you are experiencing
do a data recovery on the hard drive
get a new drive
install and configure
restore data from disks from recovery vendor
hope that your laptop does not attempt high dive in future
back up data consistently
May 23, 2012 | Toshiba Satellite L655S5158 156Inch Laptop
Failure to bootup
This message means that the computer could not find the MBR (master boot record) & the most likely cause is a hard disk failure. To prove this obtain an installation disk of an operationg system, say Windows XP, place the disk in the drive, and while its booting up, press F2. From the menu set the boot order to... 1. CD rom drive. Save and exit. The machine will now begin to install the operating system to your hard drive. If you get the same message again, you have a hard drive failure and it will have to be rep-laced.
Apr 05, 2010 | Acer Aspire 3680 Laptop
Dell Inspiron 1526 blank screen after hibernation
Press Fn Key plus POWER key ans see if the diagnostics will start. If no go, then the system is likely in a No POST state.
You can check the warranty status here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&cs=04&l=en&s=bsd&~ck=anavml
and no paperwork is needed to get warranty support, all you need is the express service code on the bottom and be a authorized user of the system.
Oct 21, 2009 | Dell Computers & Internet
Blank screen
Turn Hibernate off for one thing. Hibernation leads to registry problems and boot issues. Go to control panel > power options > hibernate tab > uncheck the box. Reboot the machine. If you want, the laptop will go into standby mode after a period of time and will wake up with a touch on the touchpad. Go back to power options and there are settings in there that you can tailor to your liking.
Sep 30, 2009 | HP Pavilion dv2000t Notebook
PC won't wake up after Hibernate, Standby or Restart
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Jan 12, 2009 | IBM ThinkPad R40 2722 Notebook
Hibernating problem (Windows Vista)
There are two ways to enable hibernation on a laptop. When you bootup your laptop, there is a text hint for access to your laptop's setup. It is Del, F2 or F10 most commonly. Look for that hint and enter hte bios setup for your laptop. Once inside the setup, look on all the pages to find the power options for running on Adapter Power and Battery Power. In this area will be an option for the default action when your lid closes. The safest is turn off, but more commonly you will want to user Hibernate. You can set this for the action on batteries and on adapter if you want.
As you may know, hibernation requires and creates a rather large file on your C: drive that contains all the information Vista needs to reload your computer to the exact state it was in at the time you placed the computer into Hibernation.
Also, in Windows also, you can enable hibernation and set its terms. Right click a blank area of your desktop, select Properties. You will see the well known Screen Saver and Desktop Background choices interface. When you click on Screen Saver you'll notice at the bottom right a button titled Power, click on that. On the subsequent page look for and check off the box titled 'enable hibernation'. You will also see the various timeouts for Standby, Sleep and Hibernate now. You will also see options for actions such as closing the lid. You want to be certain that the actions in Windows for the Lid Closure matches the actions you set in the System Setup at boot time.
Any questions? use the comment box below to ask away.
Regards,
Worldvet
Nov 23, 2008 | Acer Aspire 4520-5582 Notebook
Cant get out of hibernation
does the laptop boot at all ? or just not logging to windows ?
if not logging to windows then unplug the laptop's battery the replug it and restart
if the problem remains,, try to boot in safe mode by pressing F8 continuously and then choose Safe Mode
if you success in booting in safe mode go to control panel and disable hibernate then try to reboot in normal mode
Dec 25, 2007 | Acer Aspire 5610-4648 Notebook
Screen on Toshiba M35x S149 Laptop blank/flickers
Ok, from the beginning. Can you do a cold boot and get into the bios? (is there an image on the screen then)
Secondly, can you connect to an external monitor and see an image?
Did it do this only when it was heading in to hibernation? If so, it sounds like the power management needs some adjustment.
If there's no image on the external monitor, you may have a video/motherboard problem, or it still could be the operating system/power management.
It all depends on if you have video in bios.
Let me know.
Good luck
Nov 10, 2007 | Toshiba Satellite M35X-S349 Notebook
Acer Aspire 5610-4648 Notebook Logo
187 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
