Question about Memorex MVD2042 DVD Player
"no disc" when disc inserted, prior to this problem player would freeze
  • Anonymous Jan 08, 2008
    player does not read dvd
  • Anonymous Apr 18, 2008
    all it says is "no disc" how do i take it apart?
    Problem Solver:
  • 7 Answers
If you cant get it to work will you be will to sell the remote let me know needs one bad cant play my mp3 on it anymore email me at josocuervo@yahoo.com
Posted on Dec 31, 2007
My blue ray player LG BP620 keeps freezing
Same problem here. BP620 freezes up randomly. I have to unplag and wait. Then it freezes up again as the film progresses. I did a factory rollback and disabled wifi. Things are working much better. Very Strange ! I will call LG tomorrow and will return this BlueRay player if they don't have a fix on this problem.
Jan 01, 2013 | LG Televison & Video
I insert a movie from the video store in the dvd player Zenith DVC2550.It got stuck in back and turn table was rotating without picking up the disc. I had open cover to remove the disc. I manage to close...
It sounds like you jammed the door gear which must be closed prior to playback. You can try to take the cover off again and cycle the insert mechanism but if you put much force on it the machine may be destroyed...
May 05, 2011 | Zenith Televison & Video
I have a friend who has a PIONEER Bluray Player BDP LX52.Despite having updated it to the latest firmware(3.71)it is not playing the RED(Morgan Freeman,Bruce Willis)Bluray.Sometimes he gets the menu and...
The firmware update needs to be done again.
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
IMPORTANT: Prior to following the steps below, go to the Drivers & Software section of the Pioneer eSupport Web site to check for available firmware updates. If a firmware update is available, it will be posted there with a list of improvements over the original or any previous firmware version. Some disc playback issues may be resolved by ensuring the BD player has the most current firmware installed.
  1. Ensure the Easy Setup procedure has been completed on the BD player. NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
  2. Ensure the inserted disc is compatible with the BD player. NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
  3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step. NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
  4. Use a soft cloth to clean the disc.
  5. Examine the disc for any cracks or scratches that might be interfering with playback.
  6. Wipe the top of the disc tray using a soft dry cloth before placing the disc on the tray. Attempt to play the disc again.
  7. Attempt to play another disc. Remove the disc from the BD player.
  8. Turn off the BD player.
  9. Unplug the power cord of the BD player from the electrical outlet.
  10. Let the player remain without power for 1 minute.
  11. Plug the power cord back into the electrical outlet.
  12. Turn on the BD player.
  13. Insert the disc into the BD player.
  14. Attempt to play the disc.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required
Apr 08, 2011 | Pioneer BDPLX52 BluRay Player
It is not playing any dvd's. It says invalid or
6. Attempt to play another disc.
NOTE: If another disc plays in the player, then the previous disc may be faulty. In this case, contact the Customer Information Service Center at 800-222-7669 to speak with a customer service representative for further troubleshooting.
7. Remove the disc from the BD player.
If the issue is not resolved even after performing these steps, then try installing the latest Firmware update if you have not done yet.
Here is the link to download and install the Firmware update.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS360
Select the correct Operating System and download the Firmware update.
Then follow the instruction on the same to install the update in the Player.
If the issue is not resolved even after installing the update, then Playe may require service.
Jul 21, 2010 | Sony BDP-S360 DVD Player
Blu Ray player turns on, displays "Welcome on the screen. After disc is inserted, "Wait" appears on the the screen and then it freezes. What is wrong?
This sounds like your Sony player is not reading the disc.
I have bought faulty DVD discs before that have given this same fault!
- I assume you have tried a disc that you know works in another DVD player?
Remember, your Sony Blu-Ray should be able to play ALL REGIONS of standard format DVD discs, so you should get sound & images from any one you choose.
Nov 06, 2009 | Sony BDP-S350 Blu-Ray Player
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the bottom.it stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
Oct 04, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Formatting?
If they do your player should tell you this when a disc is inserted
Mar 30, 2009 | Maxell CD-R 80 Minute 700MB Media...
I have just purchased a smpk2062 and have inserted the disc, but can not find how to install or set-up.
My Computer > CD Drive > MP3set3_81 > Setup.exe
This will install software. If your PC O/S is prior to WinXP you will have to install the drivers first. My Computer > CD Drive > Driver
Set up in the player as a usb device in Setup. Open My Computer, open the drive of your player, then drag and drop the files you want into your player as you would any usb storage device.
Apr 29, 2008 | Audio Players & Recorders
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Memorex MVD2042 DVD Player Logo
97 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
