Question about Tomtom GO 910 GPS Receiver
Go 710 when I turn on the device the screen says "unable to store settings:File access error. Also when I disconnect from PC I have to set it up right from the beginning, the same thing happens if I accidently push the sd card in and it pops out. It won't now connect to my mobile phone where it has done with no problem before. I have sent it away to the Tomtom repair centre. It came back exactly the same! Garmin for me next time. every time i setup the device a message comes up saying "unable to store settings file system error and I have to set it up every time i disconnect it with my computer, it wont connect to my mobile and it takes 48 hours to get fully charged
  • 174 Answers
Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Posted on Jan 04, 2008
Cant download play store
How to install
The installation process is pretty simply, but there are a few options you'll have to check in your handset's menus before we begin. So here's a full step by step guide to access all that glorious Google Play content on your Android smartphone or tablet.
1- Firstly you'll need a copy of the official Google Play Store apk file to install on your device. You can download this on your PC and move it over to your handset or download it directly onto your handset, in which case it will appear in your download folder. Either way is fine.
The latest version of the Play Store is 4.4.12, which can be downloaded from here, along with any older versions.
The download listed here is cryptographically signed by Google, so it's safe to install and hasn't been tampered with or infected with malicious software. But be aware of downloading files from other less reputable sources.
2- You'll need to enable the installation of external apk files before you can install the Play Store file. This is done by checking the "unknown sources" box in your devices settings, which will allow you to install apps from unvetted sources, in other words from outside of the Play Store. This option can usually be found under settings > security, but may also appear under settings > applications on certain devices. You can always uncheck the box again after installing the Play Store.
Next you'll need to locate where the apk file is on your handset. As already stated, if you downloaded the file using your device it should appear in your download folder, which can usually be accessed from the app drawer. However, if you had to move the file on your handset from your PC via a USB cable, then you'll need to be able to navigate to wherever you put the file. The easiest way to do this is to either directly place the file in the download folder, or install a third party file explorer, such as ASTRO file manager, in order to locate the apk.
4- Once you've found the file, tap on it to get things started and a popup will appear asking you if you want to continue with the installation. If this isn't working, check that step 2 has been completed successfully.
5- Continue to click install, passing through the list of required permissions that the app requires. A loading bar will appear, once that's completed the app is installed.
All done, it's as simple as that. Now you're ready to launch the Google Play Store and begin downloading apps.
if this does not work, please reply with the exact error code
Mar 25, 2014 | Irulu 7" Touch Screen 2gb Android 2.3...
It is show error assess after it was connected to PC
I suggets reinstall all sofwtware drivers and firmware in the pc and try again.
Keep updates.
Sep 11, 2010 | Sony ICD-P320 Digital Voice Recorder
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
File Access Error
Check the SD memory card. There is a slider on the side of the card for locking to enable read-only mode. This slide should be up to enable read/write mode
Jan 02, 2009 | Tomtom One XL GPS Receiver
Tom tom go 300 ''unable to store settings'' ''file access error'
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Nov 24, 2008 | Tomtom GO 300 GPS Receiver
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
Go 710
i have the same problem
Dec 23, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
183 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
