Question about Tomtom GO 700 GPS Receiver
Alternating beween screens; does not work
Alternates between the shutting down screen and road screen
  • Anonymous Jan 02, 2008
    the 720 shuts down in the middle of operation even with the never shut down checked off. Gives a warning will shut off in 10 9 8 etc unless touching no
  • 4,402 Answers
Reset your device
Reset your TomTom using a straightened paper clip.
If you use a PDA, check the manual that came with your PDA to see how to reset it.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Posted on Jan 22, 2008
Driving down the road the battery light came on,
Your charging system stopped working (that's what the light means if it comes on while the engine is running), and now the battery is run down too low. Take your alternator off and have it tested. You could or should also have the battery tested, but it will need to be charged up first on a battery charger. If it is 3 years old or more, you may need a new battery. First have the alternator tested at a parts store- it is a free service.
Aug 29, 2014 | Cars & Trucks
2002 Mazda tribute won't start but can jump, car will shut off while driving
you mentioned new alternator and battery, but it seem that the alternator is not charging, when you install the new battery the car started and run and after hours of running specially if head light is on the car shuts down. this is an indication that the alternator is not charging. (factory defect) have it checked or return part to auto supply.
if alternator is good and you have the car jumped and run it will not shut down even if your battery is dead because the charge of the alternator is enough to power the electrical system of the car until you turn it off. this applies to all cars
Dec 10, 2013 | 2002 Mazda Tribute
Where is my auto shut down relay switch on a 99 cadillac deville
No, this is not a SHUT DOWN RELAY.. The Emergency Fuel Shut off is one on... It is ON until you reset.
you are having a Heating system Electrical and you are getting Feedback into your System and it will continue until you address the root of the problem.
You need to find a GOOD Automotive Electrician
Apr 07, 2013 | 1999 Cadillac DeVille
Van won't start
sounds like you need a new alternator.the battery light is triggered by the diode trio in the alternator. if the light comes on.99 times out of a 100 you need to have your alternator replaced.have your charging system checked first. most parts stores check them for free.with the engine running it should be around 14.5 volts.
Apr 29, 2009 | 1992 Plymouth Voyager
Iphone fell, now has alternating frozen screens
do as i say i think it will work ........... Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Apr 09, 2009 | Apple iPhone Smartphone
Blue screen
it is coz of your problem with the RAM, change the alternate new RAM it will works.
Mar 23, 2009 | Microsoft Windows XP Professional With...
Engine shuts off when idles down
Setting the idle speed faster does not help?
  • Check to see that the choke is not partially on.
  • Inspect the ignition wires at the switch and through the wiring harness all the way to the battery and the alternator. Look for loose connections and abraded wires.
  • Drain the carbs and clean them with B12 chemtool or any other good carb cleaner. The idle circuit in the carbs is probably gummed up. To clean the carbs properly they will need to be removed from the bike. Be sure to synchronize and balance the carbs when reinstalling.
  • Remove and clean the petcock water trap and clean the trap of water and rust etc. If a filter screen is present clean it as well.
  • Set idle speed to factory specs. Do not use gas with Ethanol.
  • Check battery condition and alternator output.
Mar 15, 2009 | 2004 Honda VTX 1800
Shuts off
have you checked your batteri or your alternator also check your tps hope this works
Jul 04, 2008 | 2004 Ford Explorer Sport Trac
Tomtom GO 700 GPS Receiver Logo
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
