Take the top off. There will be 2 screws on each side where the front is hooked to the body. Unscrew them. The whole front comes loose along with the drum. Put the belt around the roller and under the roller support, then around the drum. Was easier then you thought huh.
The dryer stopped working in the middle of drying a load of clothes.It won`t start at all now.If I...
(More)
The dryer stopped working in the middle of drying a load of clothes.It won`t start at all now.If I turn the timer switch to the "cotton" setting,and turn the start switch,there is no ticking sound from the timer. When I turn the select switch to "regular" setting and turn the start switch and hold it on you can hear the timer ticking down,but the dryer won`t start. If you let go of the start switch,there is no ticking from the timer switch.
Dryer Does Not Turn On. Worked before, but does not now. Turned the on/ off knob and nothing...
(More)
Dryer Does Not Turn On. Worked before, but does not now. Turned the on/ off knob and nothing happens. Tested continuity across on/off switch (knob) and shows that switch is good. Is there a fuse in the circuit?
