Question about Casio Exilim EX-S500 Digital Camera
Lens error when on pressed "lens error" comes up on screen. what do i do?.
  • 104 Answers
Your camera must have been pressed or it must have fallen down due which there is an internal barral stuckup .This is repairable.
Posted on Jan 26, 2008
Lens error
Search Lens error in FixYa it is discussed many times.
Mar 13, 2013 | Nikon Inc Nikon Coolpix S01 Silver
My kodak m341 won't turn on......when you press the on button, the lens comes out, then goes staight back in. The screen comes on for a split second when the lens comes out. that is all it will...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 01, 2011 | Kodak Easyshare M341 12.2MP Digital Camera...
When pressing the power button, the shutter opens, the lens comes out, the screen comes on for about 2 seconds. Then the screen turns off, the lens goes back in, but the shutter stays open. I let someone...
Look closely for sand particles that may be lodged around the gaps of the lens barrel. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Kodak Easyshare C182 12MP Digital Camera
Lens error
that could be the lens cover not opening all the way, try and look at the lens as if you were doing self-portrait, and power on. if lens cover opens all the way but lens doesn't come out, the lens might be stuck or motor broke.
Sep 06, 2009 | Canon PowerShot SD850 IS Digital Camera
Nikon CoolPix L18 getting lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Mar 29, 2009 | Nikon COOLPIX L18 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
Feb 22, 2009 | Nikon COOLPIX S200 Digital Camera
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Lens Error-Nikon L2
It seems as a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 10, 2007 | Nikon COOLPIX L2 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
