if not heating, it is mostly not the heater. Can be a durty filter, the pressure switch is it mostly. look at www.oceantis.biz They can you sell allif not heating, it is mostly not the heater. Can be a durty filter, the pressure switch is it mostly.
You can't post conmments that contain an email address.
It should be OK. These units should have a flow switch to prevent activation of heating element without water flow. Yes, heating elements can be relatively easily be changed if needed.
Salt is not recommended in Portable Spas as it can be extremely corrosive to metal parts inside of the Power Pack, as well as drying out the vinyl parts, covers, etc, which can cause them to fail very quickly. The recommended sanitizer is Bromine. Make sure you are using quality chemicals if you are having problems balancing your water.
If this is leaking at the connections then you need to make sure the gasket inside the union is set correctly and then try to install it again. US Parts Center
The only place in North America to buy New Power Packs for Spa-n-a-box, Spa2go, Snappy Spa or EZ-Spa is Oceantis in Florida. They also sell remanufactured power packs and do repairs on packs. www.oceantis.com
888-997-6366 or 866-891-5585 If you call the above number, they should be able to help you find the correct item you need. Have model number ready if possible.
Is the motor running? If it is there could be a coupler broken. If the motor is not running, it could be the problem. If the motor is not running, is there power to it? If not, it may be a broken switch that controls the motor. If the motor has power but not running, then probably the motor, its starting system or bearings. Bearings? Yes, they may be frozen and or dry. Dont spend a lot of money until you have the problem located. Good luck...Lee
