Question about Tomtom ONE GPS Receiver
Time put in wrong time and need to change it
  • rp16916 Dec 28, 2007
    time is incorrect and i cannot change it
    Problem Solver:
  • 17 Answers
To change the time (clock), tap the main part of the screen. Then click on the "wrench" icon (Change preferences). Then, click on the blue arrow (4x) to go to the 5th page (Preferences 5 of 5). Click on the "clock" icon (Set clock).
Posted on Feb 16, 2008
I put in the wrong email address how do I change it it is not setting up
not sure if I understand your problem... you said "put in wrong...... now it not setting up.... if you put in wrong email and its not setup then it did not take it... so you need to put in the right email address... however if it did take it then you need to go into setup to change email address then put in wrong email then next box "new email" put in email you want to use then next box "confirm" retype your email if they match then your done.
May 14, 2017 | The Computers & Internet
How do I Reset the safe. I put the wrong code in 3 times.
I would suggest you contact either the people you bought it from or the manafacturere.
Nov 29, 2014 | Computers & Internet
Toyota 1986 MR2, turns off when put into gear
U could of got the timing off by one tooth. It does not take much to put it out of time.
Jun 16, 2012 | 1986 Toyota MR2
We took the board out and changed the convergence ic's when we put it back in and turned it on it goes from 110 volts to 0 every time you turn it on .what have we done wrong
Sounds like you have a short in your soldering. If you need tips on how to do this model or soldering goto www.TvRepairKits.com - look on their tips page
Mar 07, 2012 | Hitachi 43FDX01B TV
Forgot my password
keep on putting the password in and on the 3rd time it will say, "are you really (your name) and you put in your correct height and you will be in. then you can change the password and you are all set.
ps. if you put in the wrong height then just put random passwords until the 3rd time and put in her hieght. repeat if needed
Jan 22, 2010 | Nintendo Wii Fit for Wii
We change the cambelt and something very wrong happened, after putting everything together and starting the car.. it sound really wierd and the car is shaking. Probably the geerwheels are in wrong...
put number one cyl to tdc take out plug put long screwdriver down to check this if you are not sure /check marks on cam pulleys are correct at this point you need to use locking tool to hold pulleys still .if used before you would not have had a problem re fit belt tension turn over 2 times re check marks re check belt tension should be ok now unless valve has got bent moral always lock the camshafs on twin cam engines
Dec 16, 2009 | 2001 Volvo S40
Changing spark plugs and have the wrong firing order
all you have to do is take one loose at time to change them.as you change them put the plug wire back on.
Jan 31, 2009 | Pontiac Bonneville Cars & Trucks
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
Set time/date on Argus APS 400
I continued to push other buttons on the camera while the date or time was flashing untill I found that the mode button made it change.
May 21, 2008 | Photography
Tomtom ONE GPS Receiver Logo
54 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
