Question about Curtis-Mathis CM32010 TV
Vertical Line in center of screen
All of a sudden my tv only displays a 3/4 inch line down the center of the screen. the sound works fine and changes when I change the channel on the remote. I called a television service professional and was told that it may be a "vertical card". Researching this "card" online had yielded 0 results. I however have found several suggestions based on the same problem only with a Horizontal line. now I do not know if this card exists or if it is a componet that can be easily replaced. if anyone here has any information that may help me with this problem please reply
  • cyberdemon Dec 26, 2007
    The line in question goes from top to bottom. Sorry for not being more clear in the first post.
    Where would I be able to purchase the intergrated circuit if it turns out to be the problem? id there a IC for Horizontal or is the Vertical IC responsible for both?
  • Curtis-Mathis Master
  • 5,138 Answers
Never heard of so called card myself but ,is the line your talking about from top to bottom or from side to side in the middle?straight across middle is called horizional which means vertical problem so you have either bad capacitors 35uf 100v ,1uf 50v, or bad vertical output ic.
Posted on Dec 26, 2007
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Vertical stripes on screen.
well, change ur screen their is failure in your screen line & row moudle
Sep 29, 2008 | Televison & Video
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Bright line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Dec 05, 2007 | Philips 19PR19 19" TV
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Curtis-Mathis CM32010 TV Logo
98 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
