Question about IBM ThinkPad A21m 2628 Notebook
Help me with IBM A21M Wireless problem.
I have and IBM A21M that runs great and I was able to acess my internet wirelessly up until a few days ago. Basically I have a laptop card installed and I know the card works because im using it now, and I have tried different laptop cards with the same result. My wireless signal will connect, the disconnect after a minute or two, then it will be about 20 more mins before it connects for another minute. I have tried disabling windows configuration(so that I can use the card software) I have tried moving to another location with the laptop, I have tried a system restore. I don't know what to do and I am a college student on a fixed budget. I know there isnt anything wrong with the wireless network because there are four other computers connected wirelessly(including this one with the same laptop card that I am trying to use with my A21M). Everything was working perfectly for 2-3 months and out of nowhere this happened.. Thanks for any help.
    Genius:
  • 1,601 Answers
Make sure that there are NO electrical devices between you and the wireless router. Some electrical devices will mess your signal up.
(cordless phones are known to mess with them) too.
Microwaves interfere with the signal from your router. Interference means a low quality signal.
The following steps help you troubleshoot a bad wireless connection. Stop following the steps when the connection problem is solved:
1. Refresh the wireless connection that is giving you trouble.
2. Temporarily disable the firewall or Internet security software on the computer that is having connection troubles.
3. Open the wireless connection manager and make sure that the SSID is correct. Also make sure that encryption settings and keys match the settings in your WAP (Wireless Access Point).
4. Restart DHCP (Dynamic Host Control Protocol) on your WAP; if necessary reboot the WAP.
5. If the troublesome Wi-Fi adapter is removable - such as a USB, cardbus, or Ethernet bridge adapter - remove or disconnect it and disconnect any power cords. Then reconnect the device.
6. Right-click the My Computer icon in the Windows Start menu and choose Properties.
7. In the System Properties dialog box, click the Hardware tab and then click the Device Manager button (see Figure 1).
8. In the Device Manager window, click the plus-sign next to Network Adapters (see Figure 2).
If you see a yellow exclamation mark next to the name of the adapter, something is wrong. Right-click it and choose Uninstall, restart Windows, and then re-install the driver software as described in the manufacturer's instructions.
Posted on Dec 26, 2007
How do i connect my ibm thinkpad a21m to the internet
You need the next three letters or numbers after 2628 - ___ Go here http://support.lenovo.com/en_US/downloads/default.page?selector=expand click on laptop and tablets click on thinkpad A series then A21m Then 2628 then the next three then your operating system then voila there you have all your drives and any update for your thinkpad Bookmark so you will always be able to fix what ever may be wrong.. Please rate!!!
Nov 23, 2012 | IBM ThinkPad A21m 2628 Notebook
How do you lighten the screen on the ibm a20m laptop computer?
Hello sandee232,
The following key combinations can be used for screen brightness:
•Fn + PgUp Turn the ThinkLight on or off.
•Fn + Home The LCD becomes brighter.
•Fn + End The LCD becomes less bright.
The screen brightness information can be located inthe IBM ThinkPad A21m User guide:
http://safemanuals.com/314159.php?k=c7c8bab9c3a5ec3c048ad8dc9eb006be&ID=321133&q=IBM%20THINKPAD%20A21M
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | IBM ThinkPad A21m 2628 Notebook
I can not get win explorer to load a page it is ibm think pad a21m running win 2000. i can't get it to load a page
Are you sure you're connected to the internet? Is your LAN working? Go to control panel, system, hardware, device manager and find your network adapter(s). Click on it and see if it is working. Do you have a wireless? Do the same thing. Access to a USB wireless you could try? Install it, connect to the internet and see what happens. Sonetimes the LAN adapter in the computer will go bad.
Dec 07, 2009 | IBM ThinkPad A21m 2628 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
Belkin N Wireless Router - wireless light no longer lit up
Just in case it helps anyone else, I just had to toggle between broadcasting SSID and fixed the problem.
Jul 02, 2009 | Belkin Wireless-N Wireless Router with...
Laptop Cannot Connect To Internet
You shouldn't have to run the setup wizard. You should be able to plug it in and click on internet explorer and it will connect. This is built into the operating system. If it doesn't do this, then you will need the disc to run a system repair.
Jul 07, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM Thinkpad A21m freezes when I click on the icon My Computer
First off this machine wasn't really designed for Windows 98. Here's a couple of links that may help. The first is for a bios update to fix a few system bugs. Keep in mind that the bios are VERY important and you don't want to screw them up, so, either download and create a diskette or download and save to the desktop before running. The second is for A21 drivers. You may want to download any utility drivers that run with Windows 98. Your current drivers may be for 2000 or XP, and may be creating a conflict.
http://www-307.ibm.com/pc/support/site.wss/MIGR-4PJMXK.html
http://www-307.ibm.com/pc/support/site.wss/product.do?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=10&familyind=50281&machineind=78390&modelind=0&partnumberind=0&subcategoryind=0&doctypeind=9&doccategoryind=0&operatingsystemind=49979&validate=true
Jul 03, 2008 | IBM ThinkPad A21m 2628 Notebook
Desktop has very poor/slow connection through wireless router
This sounds like a spyware/virus problem. Try running the computer in safe mode(With networking) and see if it's any faster. You should also run your Anti-spyware,AV apps to check for problems.
Sep 13, 2007 | D-Link DI 514 Wireless Router (DI-514)
IBM ThinkPad A21m 2628 Notebook Logo
223 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
