It could be that the music you transferred has a DRM (Digital Rights Management) protection.
if that's the case, open Windows media player on ur Pc then open the music files yoou transferred. If it's on the media player window, right click on the music then choose properties - go to the 3rd tab(Media User rights) then disable the protection.
Maybe you can check at the end of the music file and make sure they are no other extension. Also, it could be that the mp3 files are encoded into a higher or lower codec which your device cant read. Check properly the files you download.
depending onm its name brand or your computer you might be able to use a media service like windows media player to sync the songs on to the device. If you want to download songs for free i would say limewire or frostwire. although most people wont use it because of th risk of viruses i have used it for years with almost no problems at all. the problems i did have with limewire was it takes up alot of space on my computer. frostwire isnt as bad for taking up space but it doesnt have as many songs as limewire.
Go to Control Panel-> add hardware then Stop here...
connect your payer
then press next -> yes i have already connected the hardware -> next->
In the installed hardware list go to the bottom one "Add a new hardware device".->next
Select "Search for and install the hardware automatically" ->next
after that in the hardware category select "portable device"
then just next next and ..
it will be done .....
But the software from the samsung will not recognise it ..
connect your sansa open mediA plAyer click on tools options devices double click on your sAnsA put A check next to start sync etc... click okAy i hope that works with windows media plAyer.....
formating is the solution
for put in order just rename the music and put the first music that you wam to be the first on the list to 1 the next to 2 ...
please rated my solution
Plug in your device to your computer. It should let you know which removable disk it is. Then click on my computer right click on the removable disk and then hit format. I had the same problem I did that and I am able to download music and videos and pictures now.
right click on computer then 1. click properties 2.hardware 3.device manager 4.universal serial bus controller(open the + sign) 5.click upper one double click 6 go to driver 7.click on the update driver 8. then choose second one (advanced) then next 9.click don't search 10.then next next if it is over same process with anotherone then restart your computer and enjoy you ipod and don't forget to give rating
