Gasoline goes bad after sitting for an extended period of time.
Old school people would drain the gas out of the tank but found this lead to rust forming in the tank.
Now it is best to fill the tank with high octane gas and use a winterizing fuel additive to prevent problems.
Also remove any water from the hoses.
In the spring replace the gas and change the oil and you should be good, changing the spark plug would also be beneficial.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
This was helpful. My biggest concern was the water manifold.
" - t924
Mi T M Model CM-1250-A/C pressure washer shuts off after 10 minutes use. Wait 5 minutes and restart...
(More)
Mi T M Model CM-1250-A/C pressure washer shuts off after 10 minutes use. Wait 5 minutes and restart by pressing On/off switch. Shuts off again in 10 minutes. Works fine while on. Thoughts on problem?
runs great untill you connect hose and when pressure builds it chokes out the engine .like the...
(More)
runs great untill you connect hose and when pressure builds it chokes out the engine .like the clitch or something not working.craftsman 1800 gas unit.
I have a k 4.93m model Karcher and as soon as the water is turned on, it looses pressure and makes a...
(More)
I have a k 4.93m model Karcher and as soon as the water is turned on, it looses pressure and makes a funny sound.
