Question about Maytag MER5870 Electric Kitchen Range
Fault code f1 came on during a cleaning -
After this code came on we cancled the cleaning - and now the oven won't gerneate heat. The heating elelmetns stay cold and the temp on the control panel stays at the temp set (usually is goes to 100 degrees until it starts to heat up and slowly moves up unitl desired temp is reached).
  • 473 Answers
On maytag f1 means there is a problem in the control (erc) and will need to be replaced.
Posted on Dec 26, 2007
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
What does F1 mean on the display panel on my Jenn Air gas oven? It won't allow me to heat up the oven, and the igniter is fine.
F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Hope this helps.
Jun 03, 2011 | Jenn-Air Ovens
The digital panel is displaying -F1- and will not
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore self cleaning ceramic top electric stove flashing f1 and beeping constantly
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F1 Code
GHYTR
Oct 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The self-cleaning mode will not stop on my Kenmore oven
Aug 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The top oven beeps and an F1 is displayed in red where the clock is located, What to do? Can I still use the oven and clean it?
Jul 04, 2009 | GE JTP48 Electric Double Oven
F1-1 flashing in gemini electric range won`t let us use oven
&^TG
Jun 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Range control panal flashes F1, oven no longer works.
$%^TG
Jan 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
What is an F1=4 error on the clean cycle on a Maytag gemini range
Dec 03, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5870 Electric Kitchen Range Logo
158 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
