Question about Creative Labs Zen Digital Media Player
My screen would go black.
Ok so i just got this mp3 and I turned it on few times and it was just fine. but then i was going to add new songs to it and it would start up but then the screen would go black! Help!
  • 1 more comment
  • clippy2 Dec 26, 2007
    I just got this player. I was loading media on it and the wizard froze. I shut down the wizard then restarted my computer but now the creative zen screen is black. The blue light is on, but I can't get any reaction from the zen. It's brand new. Help!
  • Anonymous Mar 22, 2008
    my ZEN's screen is blank when I turn it on AND when i reset it. Once i turn it on, it cant be manually turned off. I have to reset it and the screen is still blank with the power light still on. HELLLLLLLLLP!!!!!!!!!!!!
    my zen screen is blank. when i turn it on, it wont display the main menu or anything at all. it will not turn off unless i reset it. i have repeatedly reset and turned it back on but the screen is still blank and the power light is on. WTF!?
That's good advice. I didn't know about the reset hole. I got it to start working by first letting it power all the way down so the blue light was off. Then when I replugged it in to my computer, my computer still did not recognize it, but when I unplugged the cord from the opposite end of the usb and replugged that end back into my zen, for some reason it started working and the zen started up. That is a non-technical answer for sure, but I thought I ought to post it because that is when it started working for me.
Posted on Dec 29, 2007
If your player stops responding, gently push the end of a thin object (like a pin or straightened paperclip) into the Reset hole.
Sony nwz s544 mp3 player won't sync/add songs, running too slow?
why dnt u try opening the file and jus dragging the songs on =] good luckk
Oct 16, 2009 | Audio Players & Recorders
Sansa E200 screen stuck scribbly black vertical lines
When it is on, holding the power button in for 5 or more seconds hard resets the device. Give that a try. If not. it's possible it's been bounced one too many times and needs the LCD cable re-connected or the controller is bad for the LCD.
Dec 31, 2008 | SanDisk Sansa e200 MP3 Player
Can't get songs to play, can't add songs
I plug mine into the usb port . then i open the file where the folder says music. in the music folder i remove or delete files from it. then i add copies of new ones. that's the only way i can add music to mine because mine won't form at it with the converter. the converter says its the wrong format.but this way works fine for me. the copes i add are mp3 media player or quick time
Sep 02, 2008 | SanDisk Sansa c150 MP3 Player
Play list
Rhapsody e260:
Playlists can be made on the fly, but you have to play each song you want to add to the playlist in order to bring up the option.
Basically WinAmp is the way to go [here's how:]
First, start up Winamp and add your songs to its library.
You've probably already done this.
Next, create a playlist.
Call it "Exercise" for this example. Drag a few songs from your library to it.
Next, connect your e260 in MTP mode.
It should show up after a few seconds under the
"Portables" item in the Winamp hierarchy.
Right-click the Exercise playlist and send to your e260.
Wait for the playlist and songs to sync, then disconnect your device.
(Optional) go to your e260's playlists and confirm that Exercise didn't show up. If you do see it, then you probably have a future version of the firmware that doesn't have this problem.
Here's the kick.
Turn the e260 off by holding down the power button for a couple seconds until you see "GOODBYE."
Release the power button. Switch the lock slider to the locked position.
Press the power button and keep holding it down. The blue wheel light will come on, and then you'll see the SanDisk logo. Then the screen will go black and you'll see
Key LOCKED
System shutdown Once you see that message, you can let go of the power button. Flip the lock slider to the unlocked position and press the power button again. Now navigate back to your playlists and you should see Exercise!
Fortunately you don't have to go through these hoops with every sync. You can freely edit existing playlists and add/remove music; these actions appear to work fine. This hack is necessary only to get new playlists to show up.
Feb 20, 2008 | SanDisk Sansa e260 MP3 Player
Not Working Properly
trying holding ethier the power button for 20 seconds or power button and play together for20 seconds.
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
The whole thing is actin up im about to cry
Kat, You have a few issues, but they are easily resolved. Battery - the battery inside has come loose from the contacts. You will need to remove and re-seat the battery to allow it to charge / function. Not able to transfer files - sounds like your device may be full or close to it. Best solution would be to format the device to remove all the music and start over. With the device connected, go to My Computer, right click on the device name (e250) and select FORMAT. Just click start and ok, to the delete all music prompt. If you are not able to format, change the mode on the device Settings>mode or USB Mode and try again. If you have more questions, just add to this one. Best of Luck.
Sep 28, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
SA 4010 philips mp3 player
Here's what happened: When you first synced your GoGear to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the GoGear. Now, every time you sync you device, it adds every new file from your computer into the GoGear automatically. It will even delete songs from your GoGear that were on there before.
Go into Windows Media Player 11 with your GoGear connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding songs/files you don't want into your player.
-Tha Mp3 Doctor
Jun 13, 2007 | Philips SA4010 MP3 Player
Cant transfer anything to my player (e250)
i'm having a similar problem. every time i sync new music my computer tells me its on, but the tracks aren't on the player. it also refreshes every time i turn it on, which takes forever amd is getting really annoying. could this have something to do with my new microSD card?
Mar 05, 2007 | SanDisk Sansa e250 MP3 Player
Frozen on Refresh Database
Take out the four screws on the back and pop out the battery then put it back on. Make sure you synced the songs properly. Add to the problem how you added your songs and I might be able to help.
Good Luck
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs Zen Digital Media Player Logo
46 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
