Question about Toshiba Satellite A105-S4004 Notebook
Laptop upgrade do all laptops or notebooks has jumper pin like desktop mother board to increase fsb? I have nevada laptop with cpu intel p4 2.8ghz/533 socket 478 and i want to upgrade or change the cpu to intel p4 3.0ghz/1M/800 socket 478,will it be possible?, will higher fsb(800)work on my laptop?please i need helpful advices, thanks a lot in advanced
    New Friend:
  • 3 Answers
No, laptop motherboards has no jumpers usually. If you think about overclocking you can try any software.
Posted on Dec 13, 2012
  • 383 Answers
What can I upgrade in a laptop? Below is a listing of common laptop upgrade questions and the answers to each of the questions regarding laptop and portable computer upgrades.
Laptop questions and answers CH000618, What can I upgrade in a laptop? CH000780, How do I clean my laptop? CH000917, My PC Card (PCMCIA) does not fit in my laptop.
Computer questions and answers listing 900 - 1000 CH000910, Determining what type of memory to use in a memory upgrade.
Save to file / partition information. In addition, if your laptop did not support PHDISK or HDPREP unless there is an available BIOS update you cannot upgrade to PHDISK or HDPREP.
Hope theses links can be helpful for ya, read and follow instructions.
Good Luck, Please dont for get to Vote/Thank you.Merry Christmas
Posted on Dec 26, 2007
Mother board 533 prescoot how the accpet ram and processer
This motherboard supports DDR2-800/667/533 Memory and any socket LGA775 CPU such as Intel Core 2 Quad, Core 2 Extreme, Core 2 Duo, Pentium XE, Pentium D, Pentium 4, and Celeron LGA-775 CPUs
Feb 01, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Is it possible to upgrade to a faster processor on a hpn pavallion dv1000
here is a list of processors supported on that machine
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
Mar 15, 2010 | HP Pavilion dv1000 Notebook
Can you do a cpu upgrade on Acer Travelmate 2480-2968? If so what type of intel CPU will work on this machine?
The following CPUs are supported by the Acer TravelMate 2480:
Intel Celeron M processor 410/420/430/440/450 (1 MB L2 cache, 1.46/1.60/1.73/1.86/2 GHz, 533 MHz FSB) or higher.
So, based upon the speed of the CPU you currently have, you can decide whether you need a CPU upgrade or not.
Nov 04, 2009 | Acer TravelMate 2480-2968 Notebook
Ax4per with 1.8GHz does not recognize new 2.8GHz processor. Socket 478. BIOS is current. Is it not plug and play?
Does it POST and can you get into the BIOS? You need to set the FSB to 133MHz and the Ratio to 21x.
(I am assuming you did install the CPU correctly and installed the fan.)
If you can't get into the BIOS, you may need to reset it using JP14 on the motherboard.
Turn OFF power. Remove the AC power cord. Hold the power button in for 5 to 10 seconds. (This is done to discharge any capacitors.) JP14 normally is on Pins 1 and 2. Place the jumper on Pins 2 and 3 for approx. 10 seconds. Then place it back on pins 1 and 2. Connect the power cord and turn it on. This will set all the BIOS settiings to default and you should be able to set the FSB and Ratio.
Do you have a manual for the MB? you can get it from:
ftp://ftp.aopen.com/pub/manual/mb/ax4per/ax4per-ol-e.pdf
Thanks for using Fixya.
Wayne
Sep 10, 2009 | AOpen AX4PER 845PE P4-533MHz...
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
Cpu upgrade
where are you getting your CPU from you cant just buy any CPU laptop cpu's are made for laptops only and a desktop CPU wont work in a laptop. also what is the FSB of you original cpu if its 400 or 533 it probably wont take a processor that need 800mhz fsb
Nov 24, 2008 | Toshiba Pentium 4, 2.88 GHz (P000382340)...
Cpu upgrade
To upgrade the cpu, you will still need to use the same type of cpu. A socket 478 motherboard will not work with a socket 775 processor. The pin configuration is different.
Dec 21, 2007 | Toshiba Satellite A105-S4004 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
216 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
