LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air Conditioner
Problem for LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air...
The unit does not heat or cool when switched on.
By craigbotes on Oct 10, 2009
the unit does not heat or cool when switched on. If left on for a while, it occassionally works. It seems to indicate that I need a technitian to have a look at it. I was wondering if there are any fuses or the like that might need replacing making it a quick fix.
Clarification Request
Posted by ryanmalin on Oct 11, 2009
try turning it off and back on or unplugging it. as dumb as that sound these things have computers in them now, and not real good ones either. try reseting it, plug in the inside piece 1st and the outside 2nd and see what happens. that usually takes care of 80-90% of problems with minisplits that i occur.
Solution #1
posted on Oct 14, 2009
Not Rated)
1goodtech
Rank: Guide
Rating: 92%, 3 votes
There are some fuses on the boards but it does not sound as if it is a fuse issue due to it working on occasion. I would recommend having the refrigerant charge checked and also make sure the wiring is tight and the correct wire is used.
Was this helpful?
Yes
No
Popular Solutions for LG LS-L1210CL 12000 BTU
Questions and Unsolved Problems for LG LS-L1210CL 12000 BTU
Do you recommend LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air Conditioner?
Answer
Answer
My LG LSL121N-2 problems is stop working and indoor unit flashing five blinks.Please send me a fault... (More)
Answer
I have an LG room a/c Model # LWHD7000HR that cools for a while then the compressor clicks off and... (More)
Answer
i have two similar units (lg mni split same model), one works fine and the other no with the same... (More)
Answer
Dog destroyed the remote control unit. Need help on where to find it. Nelson
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioners Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
