Question about Sony Playstation 3 (PS3) Console
PS3 video output on SD tv is wavy with discoloration and black line
It worked fine when we connected through a dvd player to another SD TV. When we connected to RCA input [yellow,white,red] on another TV, the video is wavy, side to side and vertical movement and has bad color. This happens on a Phillips 3 year old set and on a Trinitron 12 year old set.
  • 182 Answers
When you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Posted on Jan 08, 2008
Tv screen turns black and red when playing through pioneer receiver
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I hope this helps.
Aug 09, 2012 | Audio Players & Recorders
Sound no picture with dvd player
Exchanged AmEx Rewards points for 3 Toshiba Model DS-4000KU DVD players in 2007. All stopped working. Two a year ago, one this week. Errors - can't read disc, bad disc, etc.
Warranty period is up. So I decided to open one up tonight since they were going in the garbage anyway.
Put on rubber gloves and took off the case. Unscrewed the player unit, lifted it carefully, and untaped lines from the botton of the unit.
Plugged the unit in and powered it on. Did not blow up! :>)
Jiggled some of the lines and connections. Put a disc in and it read it!
Attached it to the tv without putting the case back on. Received video. Yay! But no sound. Boo!
Jiggled the lines some more and tried it again. Working fine now.
Will put the case back on later and see if it still works.
Dec 09, 2009 | Toshiba SD-4000
JVC XV-SA602 player - I just get red and blue wavy lines on my TV, but can get audio. I've checked my component video connections and they seem fine, but cannot get video or even the menu to come up on TV....
I found the problem, or at least the solution. I set the switch on the back of the DVD to "remote" and reset the TV settings on the remote (although they had not changed and were still OK). With the TV/Video switch set to "colorstream", I finally got the video from the DVD. This was odd, because my TV says it does not accept progressive scan and my settings have always been with the switch on 480i on the DVD. The only change has been a added cable TV DVR box capable of HD (although TV is not HD). Does not seem like that should affect things since the cable box just outputs to the TV. But, at any rate, this regained our picture.
Nov 23, 2009 | JVC XV-SA602SL DVD Player
PS3 Blue Ray White lines on left side of TV
I have the same TV, and a Sony BluRay player (not a PS3). I have the same problem.
I found it only does this when playing back 24p disks. My player has an option to disable 24p output to the HDMI, and it "fixes" the problem.
Not really a fix, but a workaround.
Not sure whether it is the TV or player, and sometimes I have fixed it by turning the tv off and on multiple times.
I am going to test the player on another monitor and see if it does the same thing. If so, the player is going back to the store.
Jul 22, 2009 | Sony Playstation 3 40GB System Console
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Sony Playstation 3 (PS3) Console Logo
277 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
