Home | Ruud | 5.0 Tons 12 Seer Split Central System Air... | Outside unit runs con...
Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Outside unit runs continuously, even when system is off.
By u2freak23 on Oct 10, 2009
I have a Carrier system & Honeywell thermostat. The entire system is off (via the thermostat) and fan is set to auto. The outside condenser unit is running constantly, though.
Comments:
Oct 10, 2009
- Thanks so much for the help! Do you know where this contactor would be located? How big is it? What does it look like?
Solution #1
posted on Oct 10, 2009
Not Rated)
natro82
Rank: Master
Rating: 90%, 7 votes
On A/C units, there is a low voltage line that leads to a contactor, which engages to close the high voltage circuit to the condensor unit. Over time, the accual contacts in the contactor can weld themselves together. Try shutting off your furnace breaker but leaving on the one for the outside condensor unit. If it still runs, your contactor probably needs replaced. Contact a licensed electrician or HVAC contractor and tell them you think your contactor is in need of replacement. Is a fairly simple and quick replace, but the contactor itself is not cheap.
Comments:
Oct 31, 2009
- It would be located within the outside condensing unit itself. They are most often black with 3 screws on the top and 3 on the bottom with heavy gauge wire going to them. There is sometimes small screws to remove a small cover over the contacts to see them, but there is 240 volts there so do not mess with unless you know what you are doing. I highly recomend someone licensed to do so.
Was this helpful?
Yes
No
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
my small tank in the loft off the central heating is boiling over?
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
when this happens i open up the unit outside & there is only one test light flassing. i have to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud 5.0 Tons 12 Seer Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
