Question about Blue Microphones Ball Professional Microphone
How to use blue usb mic
I've plugged in my new blue usb mic power lights on what do i do now.I'm trying to use it in my cubase program for vocals can you help plz as i am not getting anywhere. Thnx
  • 36 Answers
It depends on your operating system, but in XP, open Cubase. Go to the audio input settings, and be sure to select "USB Audio Codec" or "USB Audio Microphone" as the input device.
In Vista, right click on the speaker icon in the taskbar (usually lower right hand corner of the screen) and select "Recording Devices". Make sure to select the "USB Audio" device, then try Cubase again.
Posted on Dec 30, 2007
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
How do i get levels from my g track mic im using cubase le 5 i only get one side level how do i fix this issue?
The mic is only on the Left channel, and instrument input is on the Right channel. So in Cubase you need to select only the Left channel in your first track, and then only the Right channel in your second track, and then you can record Vocals and Instrument at the same time on 2 different tracks.
May 02, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Recording with condensed mic and phantom
Some (very) basics with any live audio recording:
  • Have a very very quiet space in which to record, with good acoustics (this means a room that will give a flat sound, preferably one with carpeted walls and celings, but any small, well-furnitured room should do).
  • Do not mix with the interface. Simply put the gain as high as possible without clipping and mix later in your recording program (Cubase, in your case). You can always bring the level down, but trying to gain an already recorded track will introduce noise.
  • If you are recording vocals, use a pop filter. When recording anything, experiment with different mic positions to attain the best possible, clean sound.
Jul 25, 2008 | Tascam US-144 Sound Card
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Blue Microphones Ball Professional Microphone Logo
301 people viewed this question
Top Blue Microphones Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Blue Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
