Question about Roper RAS8445KQ Top Load Washer
Roper ras8445KQO washer
How to fix leak could be the metal thing behind the pump. washer leaks on bottom, in front when filling/washing and rinse/spin. all else works. thanks
  • 1 more comment
  • LITTLEGIRL4 Jan 02, 2008
    MY WASHER LEAKS ON THE BOTTOM WHEN FILLING. HOW DO I GET TO THE FILL HOSE?
  • malibu66 Jan 07, 2008
    washer leaks in front like arlenekcs i replaced drain hose it was kinked at bottom replaced internal hose clamps looks like pump leaking easy,inexspensive to replace?
  • Anonymous Mar 19, 2014
    agitator spins freely
    Scholar:
  • 196 Answers
Arlenekc : The water pump needs replaced.
malibu66,: Replacing the pump is not difficult at all.
In the above cases, Tilt the machine back so you have access to the bottom. (It there is a soft bottom plate you will have to remove it.) The pump it located on the bottom of the motor and is held on by two clips. Remove the hoses ant then the clips. The pump should slide off the motor shaft. If the pump does not come off then you will have to break it off. DO NOT pry on the motor or shaft. Once the pump is off check the motor shaft for any rust or build-up. This will have to be removed before a new pump is installed.
Line the pump up to the motor shaft to get it in place and put the unit back together then check the operation.
LITTLEGIRL4 Open the lid and find the water flume where the water comes in. This flume gets out of position sometimes. Start filling the machine and watch the flume. If there is water dripping or running down the sides toward the rear then the flume is not in position or has been damaged.
Posted on Jan 12, 2008
My roper washer leakes at the bottom while filling
1 of a few problems may have happen, However I would say the water pump is most likely leaking. But you can check the rubber hoses under the bottom by the motor for wetness Just make sure it's unplugged..
Jun 04, 2015 | Roper Washing Machines
I have a Roper RTW4340SQ0 washer that leaks profusely when it fills and throughout the washing cycles. I've checked the water valve and all the hoses associated with it as well as the pump and all the...
This model is direct drive with a front mounted drain pump. The drain pump is THE most common leak location on these type washers! The pumps do NOT generally leak at the hoses, but from the impeller side between the pump and motor. There will be a telltale water mark on motor side of the pump shell.It can easily be fixed by popping the 2 retaining clips, removing the two drain hoses, and pulling off the old plastic pump, replacing it in the reverse order after cleaning the end of the motor shaft. Pumps run about 30 dollars. If you are sure this isn't the culprit, check for signs of leakage between the tub center and transmission, there is a tub gasket there. The tub itself, is not likey to leak, it is one piece with heat welded seams.Go to Youtube and search Whirlpool washing machine repairs, there are a number of instructional videos that show you exactly how to repair these machines and save yourself a lot of money. Incidentally Roper is built by Whirlpool, that's why I said search with that name.
Hope this sheds some light on the problem
kcomp1863
Jan 19, 2011 | Roper RAX4233PQ Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Roper washing model number ras7133pqo leaking
lean it back look st the pump if water on it take it off 2 clips hold it on and check seal looks bad? ...replace thumbs up
VE6GAR 73 88 99
Aug 10, 2009 | Roper RAS8445KQ Top Load Washer
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Leaking
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 21, 2008 | Miele Novotronic Premier 500 Front Load...
Leak
THE PUMP IS LOCATED IN THE FRONT OF THE MACHINE.
CHECK IT FOR A HOLE IN THE FRONT CENTER OF THE PUMP AND CHECK IT WHERE THE MOTOR SHAFT CONNECTS TO IT. IF YOU FIND ANY MOISTURE THERE, REPLACE THE PUMP.
Apr 10, 2008 | Roper RAS8445KQ Top Load Washer
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
306 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
