Question about Akai LCT3701AD 37 in. LCD Television
  • 217 Answers
SOURCE: Akai pdp4298 42 in. plasma
The clicking sound is the relay switch on the power board, it could be the power board or the logic board
Posted on Feb 18, 2007
  • 440 Answers
SOURCE: Hitachi 50" plasma no picture
well they give usaly 1 yr parts labor i would get it in asap to be fixed bad power thx nick
Posted on Feb 07, 2008
  • 6 Answers
SOURCE: 42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Posted on Mar 02, 2008
SOURCE: hp 42 plasma tv cptoh 0602 I get sound but no picture
HP is now fixing this problem for free. all you need to do is to call them, even if your warranty has expired. I have The same problem like you, and my warranty has expired, I just called them on Sep 19th 2008.
do not hesitate to call
Posted on Sep 20, 2008
  • 7 Answers
SOURCE: Shaky picture AKAI PDP4298ED1
Posted on Mar 29, 2009
  • 1077 Answers
SOURCE: AKAI 50'' Plasma PDP5006H Main Power Supply Board p/n LJ4400057A
I looked around for a power supply for you and turn up nothing. I see your problem. Nobody is selling. Best just to fix the board itself.
What I would do is get a Service Manual over the internet. is selling the Service Manual. Usually cost under $20. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part number lists. And most cases the new part cost less than $15 by searching on the internet with the part number.
It's possible that it's just a bad capacitor or transformer on the power supply board. Cheaper than replacing the board.
I hope I solve the problem for you.
Posted on Jul 20, 2009
0 characters
1 Points
I have a LCT37Z4AD 37" TV w/ built in dvd player.
Have you tried inserting the DVD the other way round? The label might need to face the other direction. If not, it is a defective DVD drive.
Feb 28, 2011 | Akai LCT3701AD 37 in. LCD Television
No picture or sound.
Replace ysus board!!
Check all supply rails before replacing,
Apr 02, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Akai 27 inch Flat with built in DVD wont show picture/turn on
I just purchased a referbished Akia LCT37Z4AD. I plugged it in and it worked great but it still needed moved into place, on the entertainment center. Well it done the exact same thing while moving it. I simply Moved it around and it turned back on. I believe this is happening because of a hazard mechanizme that trips when moved or shacken. Something like an electric heater does when knocked over. Not 100% sure and I just started researching it so I will write back when I know the exact problem.
Jan 30, 2009 | Akai LCT3701AD 37 in. LCD Television
Akai pdp4273m1 has sound but no picture
I also have the akai PDP4273M1 tv with power and no picture and I looked at the power supply board inside and found 1 of the FMG26S chips blown and I am looking into replacing this to see if that does it and if not do a search for SANKEN PSC10165B M and for approx 170.00 you can get a whole new power supply for it and its easy to put in..
Jul 14, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Sound but no picture.
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If things do not improve after you replug it, then your TV has a more serious problem, that requires the attention of a repairman.
Jul 03, 2008 | Akai PDP4225M 42 in. Plasma Television
Akai LCT2721AD - Power on - Sound on - Black screen (No Picture)
Ive reviewed and assisted anoter person who had a similar problem that caused the tv to malfunctioin simialr to yours. After doing some short research and the other person who had the problem, came to find out that 4 resistors failed on the main board causing this to happen. It also could be the backlight of your Plasma screen tv, or your Plasma screen itself is shot.
I would recomened that if you have no active warenty to give a visual inspection of the Tv, via removing the rear black plastic pannel to see if any of the corisponding chips have any burn marks or excessive heat stress. these items seem to be failing about the 12 month mark
Good luck
May 12, 2008 | Akai LCT2721AD 27 in. LCD Television
No picture or sound
what do you have connected? you can try withe basics. if you can try a rg-6 cable into the f connector. then try a dvd on video 1 and change the input to input 1 and see. if nothing else try a hard reboot
thats unpluging the tv for about 2 min. then reconnect.
Apr 08, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No Picture or Sound
Dec 04, 2007 | Akai PDP-4216M 42 in. Plasma Television
Sep 03, 2006 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT3701AD 37 in. LCD Television Logo
135 people viewed this question
Top Akai Flat Panel Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Flat Panel Television Expert? Answer questions, earn points and help others
