Question about Cerwin Vega 154 Car Subwoofer
Can't get my amplifier to work.
I have a 99 GMC Denali I had a local store hook up all the stuff to adapt from bose system to a after market CD player a Alpine model# cda-9827 and I put a sony 1200 watt amp in to.My problem is I can't get the amp to work or push the subs.I've did everything.I also noticed when I un hook the rca the subs where still leting the sound from the radio come through.It's driving me nuts i really need help please....
    Problem Solver:
  • 15 Answers
Hi there by the sounds of things they may have connected a high input feed to the amp as well as the rca leads but the amp is probably not switching therefore will still let sound pass straight throught amp as a junction, you need to check that sub channel on the headunit is on and the amp is powering up there should be a signal light on the amp
Posted on Dec 29, 2008
    Problem Solver:
  • 14 Answers
Any idea how this is all wired up?
I think what they have may used is an 'RF modulator kit' to get the signal from your stereo to the amp. These are commonly used when factory stereo's don't have any outputs on the back of them for adding external amps. Even so, when you unplug the RCA cables there should be no signal coming to the amp & no sound coming out of the speakers/subs that are subsequently connected to the amp either.
Posted on Dec 28, 2007
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
How to clean lens on cd player?
Purchase a CD player cleaning disc. Try Best Buy
May 09, 2014 | 2005 GMC Sierra Denali
Bose 6 disc cd changer
no.
purchas an adapter that will allow you to convert one of your XM channels to an AUX input.
Apr 09, 2014 | 2002 GMC Denali
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
What do i need to install after market cd player in my 2004 GMC Sierra?
The sad part about installing into alot of GM cars is that the Harness is about $100 bucks
You need a Metra GMOS-01
You need a metra 40-GM30 ( Antenna adapter, since the stock plug wont plug into after market radio)
And a Metra 99-2003 ( dash kit
Apr 06, 2010 | Pioneer DEH-P2900MP CD Receiver...
Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
Jul 07, 2009 | Bose Acoustimass 16 Speaker
My homie had the same problem with his escalade they adapted an rca line adapter from the factory wiring to geta signal to his amplifier and it just wasnt hitting like it should so we installed a new deck and plugged the rca cords right into it and boomboom pow it was hittin like a champ-we figured that the stock premium system that was incoprporated into the truck had some sort of an onboard amp that was filtering the bass from the door speakers and which was limiting the bass output to the rca adapter and thus on down the line to the amplifier- so maybe ya might want to look into getting an aftermarket deck and see if that helps your cause-good luck
May 21, 2009 | Alpine MRP-M450 Car Audio Amplifier
2005 GMC Yukon Denali Bose CD inop
04 yukon denali bose system c.d. are stuck nhon will play gives me code E.Q.-4
May 19, 2009 | Car Audio & Video
Cerwin Vega 154 Car Subwoofer Logo
262 people viewed this question
Top Cerwin Vega Car Audio & Video Experts
Frank de Armas
Level 1 Expert
Chris Larocque
Colin Stickland
Colin Stickland
Are you a Cerwin Vega Car Audio and Video Expert? Answer questions, earn points and help others
