It might not be defrosting! The ice is block air flow to the fresh food section.
To test whether the defrost timer is simply failing to
advance, locate the advance screw and turn it clockwise until you
hear it click. This advances it to the next mode. If it was cooling
before, it is now in defrost mode. Simply wait about 35 minutes
and check whether it has left defrost mode and has resumed cooling
(listen for the compressor). If it does not advance, the timer
motor is probably bad and the entire timer needs to be replaced. If
it advances as it should, then you can follow the steps below to test
the switch electrically.
The timer is usually held in place with one
or more screws. Remove the screws and gently pull the timer
out far enough to disconnect the wiring connector. The connector
can be removed by firmly pulling and rocking it left and right. It is
not necessary to note the position of the wires because the connector
plug is keyed so that it can be replaced in only one way.
It is quite common for a refrigerator to begin the first signs of a defrost problems once he fresh Food section begins to warm. Auto Dampers are an additional component to check while searching for the true reason for Fresh Food compartment warming. First look inside the freezer compartment and and see if there is a layer of frost building on the rear wall. If yes you will need to manually defrost unless you have anothr place to store the freezer goods. Unplug refrigerator and then remove the rear panel of freezer to get a good look at the snow covering your evaporator coils. Defrost with a hair drier. Now we need to look for the cause Auto Damper, Click here for the photo location of these parts=> MSD2756GEW Controls Section the adaptive defrost control is most likely the problem and is listed in the photo as location 13 and the auto damper
61005971 Damper Control Assembly
61005988 Adaptive Defrost Assembly
The Auto Damper model refrigerator has two controls and both have capillary sensing.
The Auto Damper controls the fresh food temperature and the Freezer Temperature
Control guides the freezer temperature. The fresh food compartment temperature is maintained by a damper assembly located at the back of the temperature control housing. Changes in air temperature cause the damper door to open and close. A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the coldest position increases the flow of freezer air into the fresh food section. The freezer compartment temperature control warms at a faster rate and cools at a slower rate, increasing the compressor run time necessary to maintain a satisfied freezer temperature control.
Click Here=> Here is how to test a Maytag MSD2756GEW Auto Damper
There is always other possiilities but I see two other things that may cause this and that is the defrost heater with defrost Thermostat=> 61006199 Defrost Heater Assembly
I know this was long and possibly confusing but please ask if you should have questions or one on one assistance, Thanks, Sea Breeze
