Sounds like a memory mismatch likely dual rank and a single rank module. Especially if both modules work in either slot
Testimonial: "I'm thinking it has to be also Thanks"
Your memory rams are having an incompatibility issue.
your macchine goes up to 2 gb i will recommend just to get a second mem of 1gb same ddr2 non ecc cl4 dimm. depending on the brand they have different Mhz. try to use same Mhz. it may be the reason you machine does not work with the 2 modules at the same time.
Testimonial: "I kinda thought that might be but I was in denial cause I don't want to send it back. Thanks"
