1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out. Regards, Bruce www.fixyourboard.com
Installed in April 2009. Tuesday I baked all day in both ovens. This evening, Wednesday, the bottom...
(More)
Installed in April 2009. Tuesday I baked all day in both ovens. This evening, Wednesday, the bottom oven will not turn on. The light comes on but when I push Bake, there is only a beep. Nothing else.. I am currently baking something in the top oven but the bottom oven won't start.
The beep is regularly irregular, that is, it beeps at regular intervals, and then stops for a while...
(More)
The beep is regularly irregular, that is, it beeps at regular intervals, and then stops for a while and then starts up again, whether the oven is on or off. Please advise. Thank you
Hello, I have a Jenn-Air electric double oven. The top one is self-cleaning. I turned on the...
(More)
Hello, I have a Jenn-Air electric double oven. The top one is self-cleaning. I turned on the cleaning mechanism and after completion, I cannot unlock the door to open it. The unit is approximately 10-15 years old. Pleasse help. Thanks - Jo
