Question about Brother MFC 240C All-In-One InkJet Printer
Printer screen tells me that there is a paper jam - no paper left in printer
I was printing 4x6 paper when a jam occured removed jammed paper but now the machine keeps telling me about a paper jam - i've checked everywhere and can't find any more paper in there. Do I need to reset it or something?
  • Brother Master
  • 1,113 Answers
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Posted on Dec 25, 2007
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
Paper jam
Unplug the printer from power for ten minutes.
Remove cartridges and put them back, open all doors and close them back.
Oct 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
We have a esp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
Reset the printer:
  1. Turn off your printer.
  2. Wait 30 seconds.
  3. Remove all paper from the paper input tray(s).
  4. Make sure the paper output tray are open and free of any paper.
  5. Turn on your printer
Clear paper jam:
  1. Open the paper tray and remove any paper.
  2. Remove any foreign objects.
    autourg01093003id2991643
  3. Remove the cleanout assembly from the rear cleanout area:
    • Gently press and hold the tab on the left side of the cleanout assembly.
    • Carefully pivot the left side of the cleanout assembly toward you to remove it.
  4. Check the inside of your printer for a paper jam. If necessary, slowly pull the jammed paper from your printer.
  5. If paper is not visible, check your printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
  6. Check under the printer for obstructions. Remove any debris. If necessary, relocate the printer to a flat, hard surface.
    IMPORTANT: If the cleanout assembly is not installed and seated correctly, paper jam or paper tray empty errors may occur.
  7. Install the cleanout assembly:
    a. Insert the right side of the cleanout assembly into the back of the printer so that the tabs fit into the slots on the right side of the cleanout area.
    b. Rotate the left side of the cleanout assembly until the latch snaps into place.
    c. Pull on the cleanout assembly to insure that it is seated.
  8. Go to Upgrading all-in-one printer with latest firmware and follow the instructions to download the latest firmware version.
  9. Open the printer access door.
  10. Remove any debris or obstructions.
    autourg01093007id2994051
  11. Connect:
    • any cables that were disconnected
    • Power cord
  12. Wait 30 seconds, then turn on the printer.
hope this helps
Dec 04, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
Paper jam problem
Remove the back cover and put an index card thru where the paper goes, that should push out any left over scraps.
Jul 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Paper Jam
  1. Press the On button and then unplug the power cord.
  2. Press in the tab on the rear door to release the door. Remove the door by pulling it away from the unit.
  3. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  4. Replace the rear door. Gently push the door forward until it snaps into place.
  5. Plug the power cord in and then press the On button to turn the unit on.
  6. Press OK to continue the current job.
Aug 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
Could you please tell me how to release paper jammed in a hp photosmart c3175 ALL IN ONE printer scanner copier,if I pull the paper it just tears away. Thank You . RAY WINCH. EMAIL...
Clearing a paper jam from the rear door Follow the steps below to clear a paper jam through the rear door.
  1. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the unit. Figure 1: Removing the rear door c00652942.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all of the pieces of paper from the unit, more paper jams are likely to occur.
  3. Replace the rear door. Gently push the door forward until it snaps into place.
  4. Press Cancel to continue the current job.
Clearing a paper jam from the front door
  1. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door c00652943.gif
  2. Gently pull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the unit, more paper jams are likely to occur.
  3. Close the print cartridge door. Figure 3: Closing the print cartridge door c00652944.gif
  4. Press Start Copy Black or Start Copy Color to continue the current job.
Aug 06, 2008 | HP Office Equipment & Supplies
Brother MFC 240C All-In-One InkJet Printer Logo
423 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
