Water shutoff water will not shutoff between rinse and spin cycles. shutoff valve has been replaced
    President:
  • 1,294 Answers
Are connections to the new valve okay. If not you have faulty new valve.
Posted on Dec 26, 2007
  • prem mathew Dec 26, 2007
    Plug off the wall. Open up behind the machine, you will find a thin rubber tube going from the pressure switch near control panel to the pump and exit area; remove this tube from the top & blow into it, it should be free from any blockage or damage, refit. This tube regulates the water level and switch. If damaged, replace.
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
When the 'wash' cycle finishes, the machine stops at the 'rinse and spin' cycle, and the 'prewash' LED flashes.
Victor. The prewash flashing is indicating a water fill issue. Rinse uses cold water only. check for clogged inlet screen on the cold water valve, and check if there is a screen on the supply valve also. If the inlet screen is all clogged up at the valve on the washer, you can clean it with a little windex and an old soft tooth brush. gently brush away any sediment or debris. If no filters are clogged, you will need to replace the fill valve assembley.
Apr 10, 2014 | Hotpoint WMA50 Front Load Washer
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
Stuck on rinse cycle
Your water valve is bad or the cold side of the valve is stopped up with sediment. Clean the water valve inlets. If that does not correct the problem, replace the water valve.
Jun 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
