Question about Gateway FPD1530 15" Flat Panel LCD Monitor
FPD1530 monitor - no display
My FPD1530 no longer displays anything except for a brief moment on startup. The power button is lit up but the display goes black.
  • khanutin Feb 10, 2008
    where can i buy cable for fpd 1530 monitor?
  • Anonymous Mar 24, 2008
    my gateway fpd1530 monitor comes on for a split second then goes back off, whats going on with it? can anyone hlep, sometimes it says input out of range...
  • 105 Answers
There are multiple curcuits for this model.
Quick turn off of the backlight can be caused by deteriorated solder connectiond on Q6 & Q10 on the power supply/inverter board. Resolder and reassemble. (board mfgr: BI Electronics)
Monitor Mike
Posted on Oct 02, 2008
I recently fixed 4 fpd1530's with the problem you describe. The fix is to replace capacitors c105 and c106 located on the left side of the power supply board. Both are 1 microfarad 50V parts. The fpd1530 is very easy to work on. Total repair time after initial diagnosis averaged about 10 minutes.
Posted on Sep 27, 2008
I had the same problem but i fix it.
Open your screen and remove the power pcb.
Take a look on solder side, if your problem is the same
then mine you should see a bad or cold solder. Remake this solder and it should be ok after.
The cold solder can be on the small coil .
good luck
Posted on Jun 30, 2008
  • 74 Answers
Time to replace the monitor if it can be repaired it would cost more than a new one.if you can find a tv repair shop that does free estimates im sure they will verify that.
Posted on Dec 26, 2007
Shut down my Acer 2480 wrong by pressing the power button. Now it doesn't reboot or boot up. I tried to pressing F2 to reboot but it doesn't do anything. Any suggestions?
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. If the computer has a battery, it may be low and unable to power the computer. Connect the AC adapter to recharge the battey pack and make sure the AC adapter is properly plugged into the computer and to the AC power outlet.
If the power indicator is lit, check if a non-bootable (non-system) disk or USB thumbdrive is in the computer. If so, remove it and press Ctrl + Alt + Del to restart the system.
Pressing F2 by itself is only used to enter the system's BIOS on startup. If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
Apr 03, 2011 | Computers & Internet
Dead monitor except for a brief moment when turned
We do out of warranty repair. Check our web site at:
www.ccl-la.com We should be able to do your repair for $35 plus return shipping. If you need additional information about the repair you can call us at 318-447-9040
Buddy
Corporate Computer
www.ccl-la.com
Jan 08, 2010 | Emprex LM2201 22" LCD Monitor
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Jan 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Help
Take every single cable out of the unit, now power on the unit.
If the power protection still shows then there is an internal fault, usually a short or a component defect.
If it powers on ok, switch off and insert 1 speaker at a time and power on the unit until the protection mode comes on again, the last speaker you have put in has overloaded it for some reason, also as you are trying each speaker use the volume and bass controls to see if there is an internal overload.
Thats as much as I can offer you until you narrow the fault down to the unit or one of the speakers.
Cheers
May 13, 2008 | Samsung HT-X40 System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Mar 01, 2008 | Samsung HT-X40 System
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
709 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
