Question about HP OfficeJet 7410 All-In-One InkJet Printer
Melted plastic under black ink cartridge
The error message says .."print cartridges .. not intended for this printer". They are HP cartridges. Upon closer inspection I notice that a black plastic well area under the black ink cartridge has black ink on it, and the plastic well area is largely MELTED away. Yikes!!!
Ever heard of this? Any easy repair? I have had this printer for maybe 10 months. Thanks, Bart
  • HP Master
  • 1,113 Answers
10 months well then it is under warranty still. HP replace machines under warranty, no easy fix, never known of melting.
Posted on Dec 26, 2007
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Printer Error Message
Yes, there a few items you need to consider with respect to HP 61 (or 61XL) cartridge errors messages on any HP Deskjet 1000 through 3510 printer model:
If you get an HP 61 / 61XL integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore ink low, non-genuine, counterfeit messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of this low ink phenomena.
If the new (or refilled/reman/compatible) HP 61 / 61XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. Ensure you press OK or Cancel up to six times to clear out the printer error log.
These types of severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Test
http://www.youtube.com/watch?v=tMZkqE36ifk
Aug 24, 2012 | HP Deskjet 3052A Wireless e-All-in-One...
Error message the following ink cartridge is not intended for use
I would replace the ink cartridge in question because each one has it's own circuit board and it appears you have a conflict in the printer.
Mar 06, 2012 | HP Officejet Pro L7590 All-in-One InkJet...
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet F380 All-In-One Printer
Black Ink Cartridge alignment problem
I have never heard of that happen before. I know if they have been refilled they lose there effectiveness causing leaks to happen.
Jun 14, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP 1610 Won't Recognize the Color Cartridge?? Please Help!
i don't know who checks these messages, but I have the exact same problem, also with my mom's printer. it is no longer under warranty so HP wants to charge me thirty dollars for them to tell me how to fix it over the phone. no thanks.
Jun 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
