Question about Hitachi 43FWX20B 43" Rear Projection Television
Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Hitachi 43VWX10B Rear Projection television. - The colors are out of alignment, causing shadowing. Magic Focus does not work to resolve. How can I adjust it
  • 1 more comment
  • milancricket May 19, 2008
    I have the shadow problem also. I tried the majic focus but within seconds it goes out again. what can I do?
  • Anonymous Nov 13, 2008
    Magic Focus no longer works! 5 years old
  • pdwesley2009 Jan 20, 2009
    Rest assured it will be your IC chip I had my problem with ghosting red lines tried the Magic Focus to no avail the number 4 apperared telling me it was the IC chip re: convergence which aloines the colours And yes the set was bought in 2002.Had to have it replaced.
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiHitachi 43VWX10B Rear Projection Television - colo - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
I have a problem with the red not lining up the way it should. Screen shows double pictures. Magic Focus doesn't even fix the proplem. Got a code 5. Was told that the video board needs replaced but can't find a part number for it. Most places even want $100 or more just to come look at it.
Posted on Jan 21, 2009
  • 4,234 Answers
Either the pins on the convergence ICs need to be resoldered or the ICs need to be replaced. These are large black ICs attached to a heat sink and should be marked STKxxx. Resolder first. If that does not resolve it, replace the ICs.
Dan
Posted on Mar 17, 2008
How do i fix a color alignment problem?
Tries push the button said FLASH FOCUS or manual + - convergence alignment adjustment?Yes,n o,used?The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too on the convergence board,must replaced these parts to fix it.To solved tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 27, 2011 | Hitachi 46F500 46" Rear Projection...
I hae a Hitachi 53in, widescreen, on the screen it looks like the colors are seperating. Would this be the lenses, if so how do I recalibrate them? Thanks, Drew
That would be the convergence. This usually can be adjusted either through a menu or by adjusting controls inside the set. To do this properly, you need a signal generator to create a grid on the screen so the three colors are aligned with each other.
Jan 22, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Digital Aray is off. We are seeing 3 or 4 of each image. Each one a different color.
Your convergence is very "way off."
You should be able to adjust it by going through the menus until you find the one option for adjusting convergence.
Note that this allows a finite amount of adjustment. If the television was dropped or roughly handled, a mechanical alignment may be in order. Preferably by a tech that makes house calls to minimize the amount of movement and reducing chances of reoccurring.
Jun 25, 2010 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Red color is not aligned
Try adjusting the convergence. If it won't move see below
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Oct 02, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi ultrascan hd 42 in
The problem you are facing is a common problem in all rear projection TVs. It's called convergence. If you go into your menu there is an adjustment for it. if it doesn't move back into alignment then you have a more serious problem in the convergence circuit which will require replacement of components.
C-Dog
Feb 05, 2008 | Hitachi 43GX01B 43" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
1,054 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
