Often there is an access hole through which a straightened paper clip can be gently pushed to work the ejection mechanism.
Unfortunately, in consumer products this hole is usually covered by the enclosure. You could try to remove the cover. There are no persistent dangerous voltages in this type of device once it is unplugged.
However, even I, with a technical background, would not disassemble the unit unless I intended to scrap it and badly needed the disc. If you plan to have it repaired, let the technician extract the disc.
Was this helpful?
Yes
No
Popular Solutions for Philips Magnavox DVD/VCR Dual
when i insert a blank disc in my recorder Magnavox MRV640, i get a "no disc" message....
(More)
when i insert a blank disc in my recorder Magnavox MRV640, i get a "no disc" message. using different discs doesn't help and cleaning all the components doesn't help either
VCR works fine. The DVD side will start to read a disc but will never play. The noises it makes...
(More)
VCR works fine. The DVD side will start to read a disc but will never play. The noises it makes sounds as if it is trying to read it but can't.
When we switch from DVD to VCR all we get is audio. The screen doesn't change from the DVD screen....
(More)
When we switch from DVD to VCR all we get is audio. The screen doesn't change from the DVD screen. In fact if we don't remove the DVD we can see the DVD with VCR audio.
can't record then play back. when i record red light goes on, but then to review what i've recorded...
(More)
can't record then play back. when i record red light goes on, but then to review what i've recorded i hit play and nothing happens. no indication that its working. aka no play light. hooked up to a security camera
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
