Question about GPS
Air Hog Stabilizer Propeller snapped
The Airhog is a little helicopter and its not propeller stabilizer broke almost immediatedly. it's a kind of ultra-flexible black plastic. Any idea what type of glue to use on this stuff?
  • 7 more comments
  • UTCeasar Dec 26, 2007
    The rear stabilzier broke Christmas morning. Would hot glue, super glue, expoxy, model cement or even tape work? Hot glue and tape shouldn't hurt too much if they don't work, but I'm afraid they might weigh too much? Shouldn't the manufacturer have some allowances for repairing this? These are the two that fight each other, but the kids never got to do that since they had batteries only for one. Help!
  • Anonymous Dec 26, 2007
    one end of stabilizer blade broke off. tried to tape,and glue back together butit will not hold together what can i do to repair or where can i get replacement parts?
  • Anonymous Dec 27, 2007
    The long plastic piece between the two propellers snapped. Any way to replace the part??? I don't think tape will hold these together.
  • PMacUK Jan 01, 2008
    The Stabiliser for my Air Hogs Helix Micro helicopter has broken off... It will not fly as a result. I cannot find replacement stabilisers ANYWHERE on the internet - Not even from the manufacturers... Has anyone else had this problem and if so, how did you resolve it please?
    Thanks very much,
    Paul Mac (UK)
  • dat102 Oct 13, 2008
    my back Propeller snapped and my dad and I super glued it
  • Anonymous Dec 21, 2008
    i broke mine when i hit into a wall
  • Anonymous Dec 30, 2008
    1. i broke the bottom stabalizer does any one know how to take the actual stabalizer apart. It looks like you have to take out the metal pins.
  • byron_short Dec 31, 2008
    I broke the bottom stabilizer when it hit a wall. I cut the other end of the stabilizer off but the helicopter does not respond well to the controls witout the stabilizer. The up/down and left /right controls work but the forward/ reverse controls have little effect. I would like to get my hands on a new stabilizer.
  • rndsales Jan 30, 2009
    me to what a rip off
Cut off the other side mine flies just fine now
Posted on Apr 14, 2008
I fixed this problem and the result is stronger than the original. Since the tail shaft is hollow, I cut off the head of a pin and stuck the pin in one side and then glued the other side to it. The pin provides the support and surface that the glue needs.
Posted on Apr 06, 2008
We broke the stabilizer of our air hog havoc heli. Where can we get replacement part?
I replaced a broken stabilizer successfully with a regular paper staple (like the kind in a red Swingline stapler). It's the right length! I punched the staple through the stapler to bend the ends, rounded them a bit with needle-nose pliers to fit over the stabilizer pegs, then used the pliers to tighten the loops. (I got a couple of Air Hogs recently at a garage sale, but one was missing a stabilizer. Excited that it works now!)
Apr 09, 2012 | Air Hogs Havoc Heli Helicopters
Hi I broke a propeller on my storm launcher.do I have to replace the whole motor or can i just replace the propeller and where do i find these things thanks brian
my son had a few different air hogs helicopters and we were able to replace the propeller on them.you should be able to order a replacement one from airhogs website.goodluck
Mar 07, 2011 | Air Hogs Radio Controlled Storm Launcher...
I just bought an air hog havoc stinger and the stabilizer broke. where can i get a replacement part? please help!
Found it on ebay...
http://cgi.ebay.com/Stabilizer-Blade-Balance-Bar-air-hog-Reflex-Helix-Heli-/250711651055?pt=Radio_Control_Parts_Accessories&hash=item3a5f9432ef#ht_920wt_1141
Mar 01, 2011 | Toys
My rc heli wont go up
Are you missing any parts? make sure its charged, i know if you are missing a stabilizer it wont go up the stabilizer is what holds the two propellers together and when the helicopter takes a hard impact it usually comes off so check for that hoped this helped
Feb 12, 2011 | xheli 3 Channel Alloy Falcon Aluminum RC...
The little flight stabelizer thingy above the propeller on my helix 360 is not working properly. i can hold it in my fingers and while the propellers are spinning i can see the stabelizer is tipping...
Check for damage to any of the linkage. You may also remove the tiny pin on the stabilizer and take it off. use a nail file or dremel tool to round the edges... giving it a more aerodynamic shape, and you a chance to make it balanced. After you do this, wrap each tip with a small piece of clear tape. This mod is good for any of the "square" AirHog balance bars.... it gives you more response and faster movement in all directions. ~VLAD~
Dec 30, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Heli will not climb above ground effect, battery tests ok, axles in balance no vibration, just will not climb
I also have this kind of problem with my apache. The upper propeller must spin faster thatn the lower propeller if not the heli would just spin on its tail although maximum power is achieved. The solution is to check the connection of the gears and the axle of the upper propeller which is located at the bottom of the helicopter. remove first the battery pack to see clearly the connection. try to turn the upper propeller a few turns and see if the axle, gear and the metal connector is sliding. A fixed my heli buy putting a permanent glue on the axle, connector to the gear and whalla. it does not slide. Most problems of this model is the gear of the upper propeller, often times loosened specially during crushes. This will a lot help you as your heli would have power on the upper propeller for lift off. Happy flying.
Gerry1abe.
Mar 07, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Controling problem
Glue the metal pin in the hole of the potentiometer. But use some good glue. I had the same prob.
Apr 26, 2009 | Spinmaster Air Hogs CHLD Twin Thunder
Airhog helicopter
yes u can
Jan 01, 2009 | Toys
GPS Logo
1,820 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
