RCA RCU704 Series remote controlTrouble
I just purchased an RCA RCU704 series remote control and I followed all direction for both direct entry and code search.and still cannot seem to program my tv to turn off after repeatedly hitting the on/off button on the remote. What do i do?
  • 2 more comments
  • michele_alle Dec 31, 2008
    SAME
  • Anonymous Apr 23, 2009
    same problem
  • Anonymous May 25, 2009
    have a sylvania tv and i cannot program either way myself. i am about to complain to rca, they dont even have an online manual for this remote n e more either
  • ladycko
    ladycko Nov 11, 2012
    same problem with the sylvania tv. and this remote... its 2012 why is this remote still availible.
Posted on Sep 23, 2008
Rca remote rcr31w
If you need help programming your RCA RCR311W follow these steps.
1. Manually turn on the component you want the remote to control
3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wishto program. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times, and the process is exited.
3. While holding down the component key, find the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the illuminated ON•OFF key turns off.
4. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release
the component key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the illuminated ON•OFF key blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
If you require the codes go to www.rcaaudiovideo.com
http://www.rcaaudiovideo.com/remote-code-finder/
Apr 23, 2014 | RCA Televison & Video
I need help programing my rca universal remote to my vizio tv
Hello
I hereby send tou the general proceedings to synchronise a RCA remote to TVs:
[1] Manually turn on the component
you want the remote to control.
[2] Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control.
[3] Press and hold the component key
[4] While holding down the
component key, consult the Code
Lists for the four-digit code that
[5] After the fourth number is
Entry process from step 3.
These are the proceedings with RCA RCR-311 remote control. Most of the RCA remotes will have this process itelsf. OK.
Oct 10, 2011 | RCA Televison & Video
I cant program my rca remote on the tv
Hello
Setup codes for Toshiba TV with RCA RCR 311B remote control are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
Most RCA universal remote will have this code for Toshiba TV.
Programming method:
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1* Manually turn on the component
2* Locate the enclosed Code Lists.
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3* Press and hold the component key
4* While holding down the
5* After the fourth number is
OK.
Jul 14, 2011 | Toshiba 27A45 27" TV
I have 2 4 in 1 RCA Universal Remote Control RCU704 Series remotes that work so I don't want to buy any more but I would like to download a new manual. Is there one available?
RCU704 Manual Not the best looking manual, but a manual just the same.
Check out RCA's web page for the RCU704. There are several listed - all are different.
May 17, 2011 | RCA Televison & Video
How can i reset my my rca universal remote rcu704?
take out the batterys, then use the directions to input the code for the set you have
Mar 27, 2011 | RCA Televison & Video
I HAVE A SYMPHONIC 19 IN B-19WM AND I DONT HAVE THE ORIG. REMOTE..I HAVE TRIED TO PROGRAM IT WITH RCA RCU704 SERIES UNIVERSIAL REMOTE AS WELL AS A ATLAS OCAP 5 DEVICE UNIVERSAL REMOTE AND NONE OF THE CODES...
Hello
You just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Symphonic is listed in its codes. Codes are: 0906 0520
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 17, 2011 | Symphonic ST419B 19" TV
I need a code for a rca and a coby remote controle
Sanyo. 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
(TV, VCR, DVD, satellite receiver or cable box).
2. Press and hold the component key (TV, VCR·DVD, SAT·CBL) you
wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry
procedure, the LED indicator light blinks four times, and the process
is exited.
3. While holding down the component key, enter the four-digit code that corresponds to your component’s brand. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key.If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that
is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2 and try the next code listed.
Dec 01, 2009 | RCA Universal Remote Control
Cant find code
lock in our manuel for manuel code entry those universal remote dont alway got the code manuel code entry take some time it should work cheers
Jan 17, 2008 | GE JASRM24912 Remote Control
Broksonic TV code for RcA RCU704 remote control
I had a similar problem with a 1994 vintage Broksonic TV. I called the company (Hatzlachh Supply Inc. @ 800-333-9099). Broksonic TVs are not compatable with any universal remotes! You need an original factory remote. Remote for my set cost $20.00 plus shipping for a total of $24.95.
James Benson
Dec 26, 2007 | RCA 257003 Remote Control
Televison & Video Logo
587 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
