Question about Eclipse Premium 34230 Car Audio Amplifier
Reset i bought the eclipse 34230 amp for $235. not bad for 4 cerwin vega 10's. but a few days after this amp lost all power. I have been told that is doesn't have a external protection but internal. i need to know how to reset it. I don't see any type of reset inside it. thanks
  • lunareclipse Dec 27, 2007
    i have tried this already. i have a jbl gtq200 running off the same line and everything is ok.
  • 631 Answers
You need to conform that you have a good ground and 12v on the remote & B+ terminals.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Dec 26, 2007
Do I need an amp as it only has regular speaker wire connections?
i believe you have a built in amp in receiver, so just do not push it, and its fine.
Jan 31, 2016 | Cerwin Vega Audio Players & Recorders
Is the cerwin vega 3200 MPLIFIER SUPOSE TO BE CONNECTED TO ELECTRICITY?
your amp requires a 12volt power wire from the battery, a negative wire grounded to the car body, a remote wire that connects to the radio or fuse box, rca jacks from the radio, and speaker wires from amp to speakers. hope this helps. please rate 4 thumbs up.
Jan 21, 2011 | Cerwin Vega Vega 3200 Car Audio Amplifier
I wanna know what the specs on this amp i just bought one recently
Cerwin Vega Vega-7000
2 x 175W @ 4 ohms (12V - 0.05% THD)
2 x 350W @ 2 ohms (12V - 0.10% THD)
1 x 700W @ 4 ohms bridged (12V - 0.10% THD)
http://ampguts.com/gallery/showgallery.php?cat=506
details and pics of cerwin amps on this site above.
Jun 22, 2010 | Cerwin Vega 2 Channel Amplifier - Vega...
Can you bridge the vega 124 or just use 1 channel on a punch 400x4
Here are the important concerns:
The power rating of the speaker(400W) should be 25% HIGHER than the maximum output of the amplifier BRIDGED. (Amp bridged output 200W - OK!)
The amplifier will get twice as warm running the speaker when loud.
The impedance of the speaker can be no less than 4 ohms when the amplifier is bridged. (Yes, this speaker is 4 ohms - OK!)
Your punch amp is capable of running TWO Cerwin Vega 124s, bridged.
Apr 02, 2010 | Cerwin Vega 124 Car Subwoofer
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
Cerwin vega ve-28s
I have the same problem and was told that it is failed amplifier....
Dec 02, 2007 | Cerwin Vega VE-28S Subwoofer
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Cerwin-Vega EXL1000D Amplifier Broken?
Call Cerwin-Vega and they should offer a "Flat-Rate" repair for it. No matter what is wrong with it, for a flat rate, they will fix it. If not, most any repair shop should be able to. If not, heck, I'LL buy it off ya! (I love Cerwin Vega stuff...)
Sep 14, 2007 | Cerwin Vega EXL-1000D Car Audio Amplifier
Information on the Eclipse Premium 34230 Car Audio Amp
Specs: 370x2 RMS@ 4 ohm STEREO (the AMP DOES NOT BRIDGE) CLASS A/B (also do not run it 2 ohms unless you like smoke) 0.004% THD @ 4 ohm 105db S/N @ 4 ohm weighted 200 damping factor 11.85" (width) x 2.05" (height) x18.50" (length) 16lbs Worth somewhere is the 200.00 range if it is in really good condition
Jun 03, 2007 | Eclipse Premium 34230 Car Audio Amplifier
Eclipse Premium 34230 Car Audio Amplifier Logo
111 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
