Question about Garmin StreetPilot c550 GPS Receiver
Recharge I have a c550 but can;t figure out where to plug it in my car to recharge. I have used the cigarette lighter for other devices, but the piece that came with my GPS doesn;t fit. What am I doing wrong? Thanks!
Or you can purchase a 3 way socket adapter as your cigarette lighter port may be to deep to accept the garmin charger/traffic antenae
Posted on Jan 01, 2008
    Problem Solver:
  • 5 Answers
The car charger worked fine in my car, but if it doesn't work for you, you can always charge it using the USB cable with your computer.
Posted on Dec 30, 2007
SOURCE:
I don't know how to make the cigarette lighter work in my 1996 Acura 3.2 TL.
cigarette lighter sockets only work with the ignition in accessories or run position
check for fuse blown
May 25, 2015 | 1996 Acura TL Series
New gps power up and shut off unespectually
GPS needs to be recharged . Recharge by plugging your GPS into an electrical outlet or into your car cigarette lighter while driving.
Aug 15, 2014 | Garmin GPS
Low battery
You need to plug it into to the cigarette lighter or your pc. I take mine in the house and connect it to the pc to charge, but it will charge with the cigarett lighter too.
Jul 18, 2014 | Garmin NUVI40LM 4.3" GPS US Mapping Text...
How I can recharge the battery?
You can charge the battery by connecting the satnav to your computer with the mini USB lead for 8 hours with both turned on. You can also charge it by leaving the car charger connected to it and plugged into the cigarette lighter socket of your car for 4 hours. There must be power going to the cigarette lighter socket. On some cars power is always available at the socket but on others it is only available when the car engine is on.
Jun 12, 2011 | Garmin nuvi 205W GPS Receiver
Can the Tomtom recharge wheh the car is not in use - eg in the garage
No, then tom tom cannot recharge when the car is not on. You need to turn on the car before your tom tom can charge. The battery gets to charge the tom tom when in use. Once the car is turned off the gps will not charge. You can try out a practical by turning off your car and plugging the gps to see if it will work. Or the cigarette lighter, does it work when the car is turned off. Since the cigarette lighter does not turn on when the car is off, then it means it gps cannot charge once the car is turned off.
Hope this information helped you!
Jan 10, 2011 | GPS
The Tomtom XXL was unplugged from the cigarette lighter overnight. What do I do to recharge it?
The device can be run from the lighter plug without being charged first. The obvious answer is: plug in the device again; when the car is key is in and electricity switched on, it should charge again.
Most Tomtom devices also come with a standard USB cable or charge cradle with non-standard connector on device end (but USB on the other). It plugs in a PC for use with the Tomtom HOME software and also for charging.
Jan 01, 2011 | Tomtom GO GPS Receiver
Fm traffic quit working the two little cars are
Are you using the Car cigarette lighter adapter plug?
If so there is a fuse in the Plug, unscrew the silver tip of plug CAREFULLY it's spring loaded
check fuse.
Oct 29, 2010 | Garmin StreetPilot c550 GPS Receiver
Will not turn on
It is possible that the internal battery has discharged, and is unable to recharge due to a blown fuse inside the cigar lighter plug or a blown fuse in the car's fuse block for the cigar lighter outlet.
  1. Unscrew and remove the silver or black, round end piece.
  2. fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e53bea0-6874-11dd-436f-000000000000%7d&ext=jpg
  3. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  4. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb=%7b6b85cfa0-194d-11dc-44cd-000000000000%7d&id=%7b6e476290-6874-11dd-436f-000000000000%7d&ext=jpg
Consult your car's owner's manual for locating the fuse block in the car. Both fuses must be good.
If you're unable to power up the c500 outside of the car (running on internal battery) your c550's internal battery may no longer be able to accept a charge. This will require a battery replacement - or use with a cigar adapter only. You may have to return the GPS to Garmin for a battery replacement - but there are some third party battery providers for some Garmin GPS units. If one is available for the c550, you may save enough money to make going the third party route worthwhile.
Please rate this replay if helpful - good luck!
You can download / view a copy of your c550 manual here.
Aug 09, 2010 | Garmin StreetPilot c550 GPS Receiver
Just got my TTone, confused about when to use the charger
To avoid an eventual loss of power while you are driving and the subsequent unsafe fumbling with the machine, you can plug the TT in the cigarette lighter during your ride. This will supply power to the GPS and recharge the battery.
Alternatively, before going on a trip plug the TT in a USB port of a computer and it will recharge the battery. With a fully charged battery and the car power adapter/battery charger you will not run out of power.
Dec 31, 2009 | Tomtom ONE 130 GPS Receiver
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Garmin StreetPilot c550 GPS Receiver Logo
121 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
