Samsung SMH7178STD 1100 Watts Microwave Oven
Problem for Samsung SMH7178STD 1100 Watts Microwave Oven
Samsung SMH7187STD restarts after a couple of seconds
By john_m632 on Oct 10, 2009
I have a 5 year old Samsung SMH7187STD over the range microwave. It begins every cooking operations fine, but shuts off (loss of all power) and restarts after a very short time. When using just time cook, just a couple of seconds, longer (about 15 seconds) when using the pre-programmed buttons. It started this problem a few months ago and has progressively become more frequent and now happens during every attempted use. Any ideas, my amateur investigation today indicates possibly the magnetron's thermal cutout?
Comments:
Oct 10, 2009
- Thanks for the info. The fan appears to be operating just fine and the air intake grill is not plugged. Is the replacement of the magnetron a do-it yourself type job. Is the magnetron accessed/replaced with the microwave installed or will it need to be uninstalled to access/replace?
Oct 14, 2009
- Helpful, thanks.
Best Solution
posted on Oct 10, 2009
Very Helpful)
charlymonty
Rank: Wiz
Rating: 82%, 227 votes
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board. 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode.it needs to be properly checked on circuit and repaired by a professional tech manually. Also Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.if yes clean it. Use an old tooth brush to help clean off the grille area
thanks,keep updated and please rate the solution positively
Solution #2
posted on Oct 11, 2009
Not Rated)
MNTECH
Rank: Guru
Rating: 94%, 917 votes
Yes it sounds like a magnetron thermal cut out, but also make sure your internal cooling fan is running. If the internal cooling fan blade moved on the shaft and is hitting something, or the fan motor is bad, that would cause the thermal cut out to trip. The longer run time for the pre-programed buttons is most likely just the additional start up time on those cycles. The actual time power is on to the mag tube is most likely about the same.
Popular Solutions for Samsung SMH7178STD 1100 Watts
Questions and Unsolved Problems for Samsung SMH7178STD 1100 Watts
Do you recommend Samsung SMH7178STD 1100 Watts Microwave Oven?
Answer
Answer
Same problem - The handle broke off when opening. Microwave less than 6 months old. Cheap plastic... (More)
Answer
under mount light will not turn off on my samsung microwave.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Ovens Experts
Top Small Appliance Repairmen
in , AR
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
