Question about HP W22 LCD Monitor
Monitor reads - "no vga signal". Thus, I have no picture. It just stopped working
Monitor was working fine until 2 days ago. Now, it will not click on to the picture when turned. The message comes up for a few seconds - no vga signal - and then goes dark and monitor clicks off. The system has only been used about 6 weeks.
  • 8 more comments
  • antdotwhat Sep 28, 2008
    "No signal" I have no picture. I plugged my Laptop into screen as my computer was booting up it was on screen as it switched to windows it went to black and No Signal message appears.
  • ilenia_rulez Oct 07, 2008
    when starting the pc an extended peculiar beep from the tower is heard every time that the monitor no signal despite windows normal running.
    Another time monitor was ok but a repeated beep from the tower was heard.It stopped by the time i turned off the pc.
    And also i have a bubble at the right bottom corner of windows informing me about the very low values of resolution but when i press windows automatically fixation nothing happens
  • wkwb Dec 06, 2008
    when computer is running there is no picture and i shut monitor off then back on and i get a picture for a second then goes off. i have two of these monitors so i hooked the other up with same cables and that montor works fine. was wondering what to do to fix or if i have to bring it somewhere to get fixed
  • monitorbabe Dec 18, 2008
    I have a nearly new Vison 17" flatscreen that has the same problem. I have to push the on button and shut it off about 20 times - then the monitor will stay on for the time that I use it. As soon as my computer goes to sleep - the monitor will revert back to black and I have to start the whole process over. It is not a cable problem - nor is it the video card. I don't know why this monitor cannot accept a power start-up without being warmed up - so to speak.
  • Allison Essinger
    Allison Essinger Jan 28, 2009
    I just bought this monitor from ebay, and sometimes it will come on and stay on, but I get a warning message telling me that the chassis needs to be set to "clear" and that it's in the system settings. I have no other problems with sound etc., but if someone knows how to get to system settings for me to reset the chassis, I'll see if that fixes the problem.
  • monkeiiilove Mar 07, 2009
    my pc turns on shows the windows then atfer it loads up the screen turns black and says no vga signal or cant find vga signal
  • bluepearlf38 Mar 30, 2009
    my monitor does the same thing.we changed the monitor to a new one but it just said no we put the other one back on and it comes on for about 3 sec and turns off.
  • sleepyb May 13, 2009
    when i turn on the computer everything comes on except the monitor the power is on but no picture
  • Anonymous May 21, 2009
    im getting the same problem only it says , blinks 5 times, then blacks out again. ive done everything to troubleshoot it an its not the video card cause it just got replaced
  • stoneheaded May 11, 2010
    To Get help for these type of problems you must give a lot more information about you system and the method of hook-up you are using. Give the monitor brand name and model number. How old the unit is . The type of computer you are connecting it to Brand name and model number. Also talk about the how the problem first started. Have you check all the set-up procedure with the instructions in the owners manuals to see if the you used the correct cables and connection points. Also have you use the correct set-up activation procedure. Usually in monitors you have a choice of connections vga and digital. The onscreen menu in the displays have a selection process to insure the correct setting. Have you check for this procedure in the owners manual. All this information will help determine if you or the monitor is having a problem with the set-up procedure. Thank you and have a nice day!
  • 149 Answers
Hi there, check the system if it is ok, if so, check your video cable, you have a video problem. try to see if there is a cold solder on video section, do some test. ty
Posted on Dec 26, 2007
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
Distorted picture on Sampo 42" monitor
This can occur due to many reasons...the simplest of those is...
Damaged monitor signal cable...results in improper signal transmission
Also check if ths is a problem with the monitor or VGA card...Just connect it to another computer...If it works then its VGA card problem otherwise its a monitor problem.If you are good in electronics then the problem is
1)You have the typical convergence failure of the convergence correction IC's which need to be replaced
2)Cpacitors on the CRT are damaged and need to be replaced..
If you are not familiar with electronics pls dont attempt a repair as it is a high voltage device and the risk of electric shock wil be high.Just drop into a service center if this is the case
Oct 12, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
My vs19 monitor will not come on. says vga input/ no input signals and then goes to sleep. I checked all connections and all are ok. Happened about 2 months ago but has worked fine since. Is there a way...
It's not your monitor. It's your computer.
If you see a display on the monitor, it means it's working. (and you do)
Your computer is not sending a signal to the monitor. If you are working with a laptop, you can just press the Fn key/special function key combo to send the signal to the external monitor.
If you are using a desktop, then you need to do some troubleshooting.
Jun 03, 2011 | HP Computers & Internet
Monitor stops displaying after a few minutes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
The picture board on your monitor is malfunctioning, since the power led or button is on and it randomly stop the dispaly signals, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 29, 2010 | HP w1907 LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
I am trying to connect my laptop to the Polaroid LCD TV, as i would like to use the TV monitor as a computer monitor (my laptop monitor is broken). So I connect the correct wire to correct places, however...
The simple patch that I found (same problem) was to start by using any old monitor that I could borrow to set up my Dell Laptop.
After getting the Laptop booted on a regular monitor I right clicked on the desktop and went to properties then to the settings tab.
Here I found the dual monitor settings (#2 will usually be dis-abled by default.)
Click on #2 monitor and set the resolution to the lowest number (800 x 600 works well)
Then I clicked on "make this monitor my primary monitor"
As soon as I clicked apply the PC Windows screen appeared on the Polaroid TV screen
Earlier I had set the secondary monitor as "extend this screen to this monitor"
This also worked but I had to "drag the current screen to the right all the way off the
"borrowed monitor" until it appeared on the TV screen. The mouse pointer will be there also.
At first it took a little getting used to but in a few minutes I was up and running.
Hope this helps your situation
David Flournoy
Waxahachie Texas
Mar 10, 2008 | Televison & Video
Monitor not receiving a signal
I have these monitors, didn't you get another cable in the pack which has a vga plug on the end? I have had trouble with those converters, try a DVI to VGA cable
Jan 15, 2008 | Gateway FPD2275W LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
HP W22 LCD Monitor Logo
1,500 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
