Question about Acer 17" AL1706B LCD Monitor
Acer Monitor Doesn't Receive Signal From Computer
I have a fairly new (about a year and a half) Acer AL1706 monitor that is not receiving the signal from the computer. It powers on, but comes up with the message, "No Signal" and goes black. Sometimes restarting the computer helps, but this problem keeps coming up.
  • miztuck Dec 25, 2007
    my monitor is a HP w17e and I receive the message -no vga signal- when the system starts up, but then the monitor clicks off and goes black. My system is operated by a gateway computer.
  • 74 Answers
Can you test your monitor on another computer to verify the monitor is at fault? If the monitor is at fault its time for a new one, factory warranties on monitors are usually 1 year unless you purchased an extended warranty.Otherwise repair is usually more costly than buying a new one.
Posted on Dec 26, 2007
Just bought a new tower acer aspire xc603 on
What signal are you speaking about, the signal to the monitor or the internet?
Oct 09, 2014 | Computers & Internet
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
Aug 25, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
My Insignia Monitor doesn't work with my laptop, I've tried everything, from pc settings to cables, etc, i only receive a NO SIGNAL ad
Usually you have to toggle the display output on the laptop. The FN key + one of the F# keys with a monitor icon on it. Toggle it until it outputs to the monitor. Your getting "no signal" because no signal is being sent to the monitor or you have the monitor on the wrong input if it has multiple inputs.
Dec 24, 2012 | Insignia Computers & Internet
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
At start up the AL1706 monitor stays black and the green light blinks on and off. I have to restart four or five times before it eventually works
cyndommett, If not into repair work, and can afford trade for new, GET NEW ONE if current AL1706 is 4, 5, 6, years old. To understand your monitor's problem, spend an hour or two reading my and other lcd monitor tech's FIXYA profile's and testimonials. Then and only then will you have a handle on what options are at your disposal and the reason why your unit has FAILED. Bye for now. 12fixlouie
Feb 19, 2010 | Acer Computers & Internet
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
Extrenal monitor does not receive signal from acer. The monitor connects easily but does not show the acer screen.
Make sure you are using the Fn key and toggling the F4 monitor key to select between the monitors or to use both... not sure if it's F4 on an Acer but look for the key that has two computer screens on it.
Jul 09, 2009 | Acer AL1703 17" LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
372 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
