Hi ok try
I found this I know your error not in here but it may work for
It worth a try nothing to lose and it may work.
I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it
Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
The HP Tech solution steps provided by ampcool56 on Oct 10, 2009 ("To my disappointment I called Hp and spoke...") - The steps worked for me! Thanks. I was about to replace the CMOS battery if this didn't work. I too replaced the printer with all new ink and still got the error message before following the steps. I did a clean printheads and got a test print - looks good. Also ran a self test report and shows ok. It is XMAS EVE and I am trying to do photos.
By the way, there is another way. By now you are getting ready to replace your printer, right? Why don?t you this last solution, and try it to resolve this issue. This step is only intended for OUT-OF-WARRANTY products ONLY as doing this step on IN-WARRANTY products can VOID YOUR WARRANTY. Do this step at your own risk.
There is a CMOS battery inside your printer that keeps track on your printer?s history. Ink replacements, resets, etc? Try resetting the data stored on your Hp product by removing the CMOS battery and then putting it back in after 30 minutes. Unfortunately I could not tell where you can find this battery inside your product as location differs for different products but here?s what the battery should look like inside your printer.
This step worked for me.... on the HP C6180 All-in-one Printer the battery is located on the circuit board on the right side of the printer where you insert the memory cards all you have to do is to remove on screw from theside and approx five that hold down the circuit board and the battery is on the other side
