Question about Sharp R-402J Microwave Oven
Sharp R-402JKF microwave
I came home and noticed the display on the microwave said 'ERROR'. The keypad doesn't work. I unplugged it for a minute and plugged it back in. Now the display flashes 00:00. The only button that works (and makes a noise) is the night light. Any suggestions before I take it in for repair?
Well guess what! MINE JUST STARTED ON FIRE! Unbelievable, I'm awaiting a reply from Sharp. A fire ball came out the right side, inside and now rests a hole.
Posted on Mar 17, 2008
    Problem Solver:
  • 5 Answers
It sounds like your electronic board has malfunctioned. It may have to be replaced, sometime it is cheaper to buy a new oven. Technician's fees and parts may be more than it it worth.
Posted on Dec 26, 2007
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
Se display
Hello Arold - Typically, error code SE indicates a shorted keypad. Try resetting the microwave by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the touch keypad on the unit will need replacing.
May 26, 2013 | Frigidaire FGMV174K Microwave Oven
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Jun 10, 2012 | Microwave Ovens
Sharp Carousel Microwave - R1481 keypad doesn't work
No! I'am afraid not, the problem is in the keypad control board, the whole assembly must be replaced, the part alone will cost around $100.00 or more depending on make and model.
Apr 16, 2012 | Sharp R410L Microwave Ovens
I have a Samsung microwave in our travel trailer, and all of the sudden, the keypad reads to press 6, but none of the keypad buttons are working, and the message keeps scrolling on the readout display. I...
This is a microprocessor problem in the appliance. It can often be reset by unplugging the device, waiting 10 minutes and plugging it in again. If that doesn't work, you will probably have to replace the appliance (cost to buy a new one in usually a lot less than trying to get it repaired).
Oct 10, 2017 | Samsung 1.8 Cu. Ft. Over-the-Range...
I have sharp microwave oven model R-231F. On digital display (which is suppose to show time) only 88888 is displayed. suspect fault with the PCB behind display or keypad. Please advise how I can obtain...
First I would suggest a "hard reset". Simply unplug the oven for a minute or two, then try again.
If it still fails, it may be that the keypad has failed, or there is a bad connection due to moisture, grease, etc.
This is an Australian model, so it's hard for me to give more specific information.
But one some US models the LCD and keypad connect to the circuit board via a rubber "zebra strip" and losing that connection can result in a loss of display segments and / or key response.
I've attached a diagram showing where one can clean to restore operation in this case.
Oct 01, 2010 | Sharp R-1480 Microwave Oven
Sharp microwave 1200 watts keypad showing
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
Oct 24, 2009 | Sharp R-510HW Microwave Oven
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Sharp R-230 Microwave Oven
Sharp R-402J Microwave Oven Logo
162 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
