Question about Dahlquist Audio Players & Recorders
Dahlquist DQ10 Is there an internet site that has detail instructions for taking apart my DQ10s so I can get at the woofer. I'm trying to see if repairing the speaker is easy enough for me to do with one of those kits.
Don't waste your time with one of those generic surround kits. Have them rebuilt by Dahlquist. I tried to refoam them, then had them refoamed by a shop. They looked and sounded horrible! I sent them in to Dahlquist, they fully factory rebuilt them.... looked and sounded awesome! www.regnar.com or www.dahlquistspeakers.com Hope this helps!
Posted on Oct 25, 2009
I have a set of phased array dq-10's from the 70's. TO pull the woofers you need to remove the grill, four screws, 2 on each side, and the four screws holding the woofer in place will be exposed. Inside you will see a green and a white wire. It is harder but easier in the long run to un-solder these leads as opposed to snipping them, good luck.
Posted on Aug 27, 2008
Can anyone suggest me a place to take apartments in Singapore?
I can suggest you a real estate website from where you can get details of all current real estate project with their location. All the real estate project of this site are developed by China's best developer companies. If you interested to visit the website then you can just take a look at Twin Vew.
Nov 03, 2017 | Internet Computers & Internet
Get a sub-woofer to work
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 28, 2014 | Kenwood DPX500BT Bluetooth Indash Car...
I need detailed instructions on how to replace subwoofer
im an experienced installer for 15 years on car stereo..trust me when i say it takes an experienced installer 2 plus hours to do this and an average joe all day if you wish not to break panels..id take it to best buy and get them to do it..they are insured..lol..plus did you get factory woofer? if not only a select few fit.
Jun 06, 2010 | 2004 Ford Expedition
Haow do we take apart the woofer lifestyle 12
There is a gap all the way round the rear of the sub woofer between the plastic rear cover and the main body. The top gap in the center you will see what looks like a cog wheel, use a flat head screw driver to turn this untill a flat section sticks up. Make sure it sticks out all the way. Undo the 2 screws on the bottom of the unit just above where all the cables plug in. Slide the rear cover donwards and lift away.
Oct 01, 2009 | Bose Lifestyle 12 System
Blown fuse on sub woofer
1 amp 250-volt from radio shack #270-1021
Dec 28, 2008 | Dahlquist QX-4A Main / Stereo Speaker
No ac getting to power unit in woofer case
I'm not sure if Z4i is the same as the X-530. But the picture you have is a X-530 Woofer. To take apart the X-530 woofer case, quite simple.
It's a pretty simple disassemble once you get the Grill off the front. Thats the only trick to it. The really annoying part is all of the glue they put... i just took my apart. I have to get rid of a **** load of glue just to get to the FUSE! I guess they didnt want the fuse to fall out? ... they really could have saved some glue.
Hope this helps.
1) take off the grill, there are i think about four tabs that go into the case. You should be able to pry the grill off without breaking anything.
2)unscrew the black grill holder, it was what holds the grill on.
3)unscrew the speaker
4) unplug the two - and + from the speaker
-from this point on... its pretty obvious...
to take off the main board,
Unscrew all of the screws on the back of it, the outside. All of the ones on the outside of the main board. Not the inside ones, you can see a difference in the screws. You could take them all off, your going to have to take those off if you want to take the heat shield(transfer case) off. You have to take this off in order to get to the componets, like the Fuse and so forth.
to take the air intake tube off, unscrew the four screws holding it on from the inside.
the air inverter thingy, you have to unscrew the screws on the bottom of the case, your going to need some piliers or a socket.
Nov 20, 2008 | Audio Players & Recorders
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Aug 12, 2008 | JVC TH-M606 System
923 people viewed this question
Top Dahlquist Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dahlquist Audio Player and Recorder Expert? Answer questions, earn points and help others
