Question about Vacuums
Techno robot dog.
Dalmation dog that is made by techno, and we do not have the instructions to make it work.
0 characters
1 Points
Change language of zoomer dog?
Contact iRobot directly to inquire about language options available for a Zoomer Dog purchased in Germany.
Jan 25, 2015 | iRobot 1100 Dirt Dog Bagless Robotic...
My roomba no longer works on my area rug, it starts backing up continuously once it encounters the rug.
Sorry to read about your problem, I hope this helps you out.
iRobot Roomba Vacuuming Robots and the iRobot Dirt Dog Workshop Robot are equipped with four infrared Cliff Sensors that prevent robots from falling off stairs or ledges. The Cliff Sensors are located along the inside of the bumper. If the Sensors become obstructed by dust or debris, the infrared signal is weakened. Regularly inspect and clean the Sensors. Use compressed air for best cleaning results.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Roomba Robotic Floor Bagless Vacuum
Stuck front wheel
I have the same problem, but it looks like no one has the solution. I have taken the screws out of the wheel but that doesn't help remove the wheel to check what is stuck. Help us!
Jun 14, 2010 | iRobot 1100 Dirt Dog Bagless Robotic...
Dirt Dog is going over stairs! Why?
On the front of the dirt dog there are 4 "Cliff Sensors" which tell it to back up or turn when it "Sees" steps. Clean these with a Q tip. If that doesnt work, go through the "Diagnostic" procedure listed here....
Mar 27, 2010 | iRobot 1100 Dirt Dog Bagless Robotic...
Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
iRobot Roomba® 562 Pet Series
Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
Dirt dog goes backwards and in circles
It probably needs to have it's coordinates reset. It has the layout of the room to vacuum stored in memory, for a pattern to follow. Try doing the procedure again that it needed before it's first use.
Dec 30, 2009 | iRobot 1100 Dirt Dog Bagless Robotic...
IRobot Roomba Dirt Dog sounds weak and stops
Generally the unit will beep or play the "uh-oh" tone or do something. I wish I could tell you what's going on with this Dirt Dog, but it's not communicating the problem. The best thing to do would be to give us a call when you have the robot with you. That will enable us to do any necessary troubleshooting as well as set up any orders that might be necessary. We're here M-F, 9a-7p, and Saturdays 9-6, EST. 1-877-855-8593 Look forward to hearing from you!
Aug 25, 2009 | iRobot 1100 Dirt Dog Bagless Robotic...
Amber light on my dirt dog wont start blinking when it try and schedule it
Dear woodzylovgf, Sat 02-21-2009 2:44am EST (USA)
RE: iRobot 1100 Dirt Dog Bagless Robotic Vacuum "Schedule"
Try clicking on the following link for scheduling @
iRobot has Great Service & Support!
If you need further assistance, please give a more detailed description of your problem...
Remember not to close any web sites but click your back and forward arrows to get back and forth!
Please click back here and rate me!
Feb 21, 2009 | iRobot 1100 Dirt Dog Bagless Robotic...
Won't start after charge.
Dear zbabe, Friday 02-21-2009 3:14am EST (USA)
RE: Dirt Dog Troubleshooting
Read the "Troubleshooting" Section of the iRobot Dirt Dog Manual @
If you still have a problem get back to me with a little more detail....
I am very impressed with iRobots Support Site @
You can even call call an iRobot support specialist at 877-855-8593!
Nov 28, 2007 | iRobot 1100 Dirt Dog Bagless Robotic...
Vacuums Logo
Top Vacuums Experts
Roger Potts
Are you a Vacuum Expert? Answer questions, earn points and help others
