Question about Garmin StreetPilot c510 Deluxe GPS Receiver
How to recharge the unit
I'm not quite sure how to re-charge it. i plugged it into my cigarette lighter but that doesn;t seem to work. i now have it plugged into the computer with the usb - can eithr method be used are there any problems with the cigarette lighter connections
  • 35 Answers
You can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Posted on Dec 28, 2007
SOURCE:
Light not coming on and getting quite hot when charging a small laptop in the car. Fan seens to be working. The unit is a roadpro rk175ub. Any answers?
R U charging directly off a cigarette lighter outlet or an inverter module plugged into the lighter? I would use the latter for a laptop
Dec 16, 2014 | Computers & Internet
Low battery
You need to plug it into to the cigarette lighter or your pc. I take mine in the house and connect it to the pc to charge, but it will charge with the cigarett lighter too.
Jul 18, 2014 | Garmin NUVI40LM 4.3" GPS US Mapping Text...
How do I recharge a Motor Trend jump starter
Get a recharge cord for the unit, plug it in and recharge.
Jun 28, 2014 | Power Center Jumpstart 11-411
Had cell phone and computer plugged into dual cigarette lighter unit and cigarette lighter overheated and quit working - we checked the fuse - it seems fine.Just want the cigarette lighter socket to work...
More than likely overheated the wiring going to the lighter as well and burned it off. If you pull the lighter socket out you should see if it did. Simply solder it back on and be careful not to overload it again.
Jan 29, 2011 | 2000 Oldsmobile Silhouette
Can the Tomtom recharge wheh the car is not in use - eg in the garage
No, then tom tom cannot recharge when the car is not on. You need to turn on the car before your tom tom can charge. The battery gets to charge the tom tom when in use. Once the car is turned off the gps will not charge. You can try out a practical by turning off your car and plugging the gps to see if it will work. Or the cigarette lighter, does it work when the car is turned off. Since the cigarette lighter does not turn on when the car is off, then it means it gps cannot charge once the car is turned off.
Hope this information helped you!
Jan 10, 2011 | GPS
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Can not figure out how to charge the Vector start it pro
Easy, just insert the "cigarette lighter style" plug from the A/C charger into the "cigarette lighter style" socket on the top of the unit, and then insert the A/C adapter in to a wall socket. It can also be charged in your car with a cord that has double "cigarette lighter style" plugs at ether end, one inserted in the Vector and the other in your cigarette lighter.
Wait, one more - clamp the units cables properly on to your cars battery terminals, then start your car. periodicly checking for full charge.
Hope it helps... Good luck
Feb 21, 2009 | JUMP START SYSTEM
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Recharge
The car charger worked fine in my car, but if it doesn't work for you, you can always charge it using the USB cable with your computer.
Dec 25, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot  c510 Deluxe GPS Receiver Logo
306 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
