Intel D845GLAD motherboard
I have 3 long beeps on D845GLAD motherboard, my screen is black i can do nothing about that.
Prior to this i add 256MB Ram memory wich probably cose this defect.
What can i do next.
Thanks
Zoran
    Sergeant:
  • 207 Answers
This is indeed listed as a Memory error by Intel
3 beeps = Base 64K memory failure
the name of that probably doesn't say much to the average PC user, but for those of us who remember the good ole DOS days it speaks volumes.
Its basically a failure of the system from recognizing any memory.
OK now we need to check the DIMM slots. these are the slots that your Memory sits in (DIMM = Dual Inline Memory Module) remove the power cord from the system, Touch one hand to the outer casing of your Power Supply( This might sound strange but it dissipates any static electricity in your body) Remove the memory modules and set them aside in a safe place (I find that the panel I take off the PC to get inside is a good spot)
Now look at the locks on the edge of the DIMM slots. Raise them to an upright position. do any of them look "Taller" than the others? If so it may have loosened up, just give some gentle pressure in a downward more( you don't need alot of force it should go easily) Once we KNOW the locks are in good shape we can move to the next step.
release the locks in just the slot next to your CPU. install one of the Memory Mods make sure the clips "Lock" into place properly and replace the plug and try to start it. If it gets past the point where the system failed before, then this module is ok. Power down, pull the plug, remove this Module and replace with the other. Now repeat the proocedure.
Did either of the Modules fail? If so then you have found the problem. If they BOTH failed something may have happened that killed both modules. If Neither failed , we likely have a "Mismatched memory" error.
Mismatched Memory ocurrs when you have two memory modules that don't quite have the same abilities. These abilities are called "Timings" and are basically just a way of measure how quickly the memory can transfer data within itself and transfer it back to the computer. Memory chips (Most anyway) have a way of telling the system what its timings are (this is called SPD or Serial Presence Detect)
Well when we have mismatched modules sometimes the SPD of the "Faster" module gets detected and not the slower. Then the system sets timings for the speedy module and the slower just can't keep up, and when the Computer looks for the data at the time its expecting it and it doesn't find it, it sees that as a memory fault and stops the whole show.
OK so hopefully we narrowed down the problem. If its a faulty DIMM replace it with a new one.
If its a mismatched memory error. First try reinstalling the memory and give it a shot. If it fails, try interchanging the DIMMS (We're seeing if the PC takes the SPD from the slower module If it is in BANK 0[The DIMM slot by the CPU]) if this works your in business.
If it doesn't work then you'll have to get DIMM by the same Manufacturer, same size and preferrebly from the same LOT (Batch of chips all manufactureed at the same time) so as to have the best match.
Hope this helps you
Dave
Posted on Nov 21, 2008
    Problem Solver:
  • 15 Answers
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. Note: Some systems might need to have a memory module in Bank 0.
  • Try using RAM chips from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
  • Trying known good memory in the system.
  • Check the power supply and check for power fluctuations.
  • Swap the motherboard
  • Posted on Dec 25, 2007
    Beeping black screen
    Do you have the manual that came with the motherboard? If you do, it should have a chart indicating what the 3 beeps mean. If not, try INTEL's website. Lots of tech info there. Don't rule out the video or RAM...the problem could be there or several other places.
    Sep 01, 2014 | Intel Asrock G41m-vs3 R2.0 Motherboard...
    Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
    u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
    1.may be the ram is damage
    2.your motherboard is not supporting 333mhz bus support
    try to find 400mhz ram instead of 333mhz
    Feb 27, 2010 | Intel D101GGC Motherboard
    I have intel D845GLAD mother board. in my system i m not getting sound so pls help me
    likely to b problem with driver..
    often follows with software corruption/os failure/faulty ram/main board..
    i guess u r using a licensed n updated antivirus..
    download, install n run microsoft kb890830
    check with the following step(s)..
    1) try download n install the audio driver http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=830&DwnldID=5500&lang=eng
    2) remove unnecessary items from boot..download n install 'Startup Control Panel'..in here uncheck unimportant startup items..
    OR 3) replace the RAM with a standby..
    OR 4) reinstall os..
    OR 5) disable audio device from the CMOS/BIOS..install a fresh PCI Audio Card n see..
    at any point of time, u may contact me/us, in case u require any guidance..
    if u r not a professional, try contact ur system admin/vendor....
    Nov 03, 2009 | Intel Desktop Board D845GLAD Motherboard
    I have a intel 845GL motherboard with 1.7Ghz
    2 x 184-pin DDR DIMM socket support up to 2 GB
    recommended: 1GB x 2 DDR 333
    http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
    contact ur system admin/vendor for more details....
    Nov 02, 2009 | Computers & Internet
    Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
    3 short beeps means Base 64K RAM failure.
    try to replace the RAM.
    Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
    What SDRAM is suitable for a intel desktop board d845glad?
    a good way to find out what ram is compatible for your board is to go to http://www.crucial.com/ you dont have to buy anything from them but they will tell you what ram is compatible
    Mar 23, 2009 | Intel Desktop Board D845GLAD Motherboard
    Sound driver
    i want intel desktop board d845glly mother audio driver
    Jan 19, 2008 | Intel Desktop Board D845GLLY Motherboard
    Motherboard is dead
    remove the RAM. boot minimal only (floppy). get to BIOS screen. reset to factory default. try again with boot floppy. if ok, re-install RAM and repeat
    May 31, 2007 | Intel SuperMicro SUPER Motherboard - 810...
    Computers & Internet Logo
    291 people viewed this question
    David Payne
    David Payne
