Question about Whirlpool MH1150XMQ Microwave Oven
Exhaust fan door flap
When its windy outside my microwave exhaust fan door flap opens & closes making a racket. I've increased the hood enclosure and added weights to the bottom of the door flap and it still does it. Any suggestions?
  • 318 Answers
SOURCE: whirlpool model MH7100XYQ microwave, exhaust fan
sometimes the control board will short out and not let the fan or cook top light work.
if you want to try and remove the control board, look on the back of the board for any burnt off tracers. those are the wiring connections on the board that move power from a wire to a relay.
it is usually easy to see the burnt out piece, and if you can solder a new wire across where the burnt out part is, then it should work ok again.
if you cant solder, then a new control board will cost about 125-150 bucks.
Posted on Jan 30, 2009
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
  • 291 Answers
SOURCE: have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Posted on Dec 15, 2009
Testimonial: "thanks very helpful will check thanks russell"
  • 8795 Answers
SOURCE: I have a WHirlpool Hood/Micro combo MH7140XFB-0.
Did your cooktop lights fail recently? If so, then the circuit board may have been damaged by a surge. We can probably repair that for you.
Otherwise, I would suspect a shorted high voltage diode or bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number (as MH7140XFB0) here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
Posted on May 28, 2010
  • 43501 Answers
SOURCE: fan does not work...including exhaust fan
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Posted on Sep 30, 2010
  • 17970 Answers
SOURCE: whirlpool gold microwave Model GT4176SPS1.
Sounds like you just need to adjust the latch assy, usually two screws you can loosen behind console and push latch assy up as hi as you can and tighten screws, sw replacement is a good idea too. There are three screws in assy. Take vent grill off, two screws, and it exposes screw holding console, pop console up and latch assy is right there to left.
Keep in mind that the door latch probably broke or one of the keepers that hold it in place broke so now the button no longer releases the door. If you remove the upper grill and then the control panel (one screw on top then slide it up) you should be able to see what is happening. But if the latch is broken or out of position, then the interlock switches will not be closing, the microwave will not heat. Check in THIS LINK the possible part replacement:
The door switch is another common problem. This switch is activated by the latch, and if it is broken the switch will not allow the oven to work.
Keep us updated.
Posted on Mar 10, 2011
0 characters
1 Points
Overhead maytag microwave fan works but no suction why
There is NO Suction on a Microwave, what you mean is Air Movement. If the Fan is turning, then there is Air Flow
Sep 22, 2014 | Microwave Ovens
Microwave VENT fan keeps running
I would say you replaced a good hood thermostat (or "TCO" / thermal cutout) with a new thermostat of the wrong type.
The oven cavity TCO and the magnetron TCO will read zero ohms continuity when tested.
They are "normally closed" devices.
But the hood vent exhaust fan's TCO is a "normally open" TCO or thermostat, so it should read open or "infinity" on a continuity check.
If the temperature under the microwave gets too high, the hood TCO opens, which turns on the vent fan until it cools back down.
I would bet that only your fuse was blown.
May 18, 2013 | Microwave Ovens
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
Steam gets in the door and how can we clean and prevent?
This is usually due to incomplete venting or impaired air flow.
Assuming your hood vent exhaust fan is running properly, be sure your grease filter is clean (or if you use a charcoal type, it must be replaced when dirty) and be sure the exhaust ductwork and outside flapper are all clear.
I recommend that you always run the hood vent exhaust fan whenever you are cooking on the stovetop, too.
You can find links to helpful exploded view diagrams and part ordering help here. You can get new filters there, too.
I recommend that you bookmark that link to your favorites.
Jan 09, 2010 | Amana Radarange Microwave Oven
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave exhaust door stuck in open and close cycle.
Depending on age You might need a new one. A repairman might be able to fix it.
May 24, 2009 | Jenn-Air JMV8166BAS Microwave Oven
Humming ge sapcesaver microwave
During operation, most of the built-in models have a panel that tilts out while the exhaust fan is on. When cooking is done, the exhaust fan shuts off and the panel retracts to its normal position. With the fan & microwave motor off, the hum is easier to hear. Look closely at the top panel the next time you hear the hum, and you'll probably see that it's retracting.
Jan 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
Whirlpool MH1150XMQ Microwave Oven Logo
152 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
