Question about Samsung Yepp YP-T9 Digital Media Player
Transferring files... Hi, my MP3 player says Transferring files.... Do Not Disconnect. Well after a few hours connected, I disconnected it from my computer and now my computer won't recognize it..and the screen is frozen on my mp3. Can you help me?
  • dat nigga Mar 19, 2008
    it froze. and now it says transferring the files and it will not come off
My brother had exactly the same problem as yourself.
wht i did was to take his mp3 player apart and disconnect the battery then putting it all back verry carfully i then tried to put things on his player and it now has no problems whatsoever.
i must stress the fact that if you do take the mp3 player apart do not touch any part of the pcb board as the static from your body will blow the components straight away.
so be carful and only touch the verry side of the board.
when putting the board back make shore that the board is angled awy from you as all the touch keys will go to the top of the board instead of being in direct contact with the keys.
i know what im talking about as im an ipc specialist.
so be warned.
Posted on Jan 04, 2008
Cant access files to use player a all
DId you delete at least 18mb as it asks? Or just reset it?
Dec 08, 2013 | Samsung YPT9 Digital Media Player
How do you take music off your mp3 player
The Sansa c140 can be operated in MSC and MTP mode for transferring and deleting music files.
See also setting USB mode for autodetect or MSC mode on page 16 of the manual: link to the Sansa c100 series manual.
  • For deleting files a connection to a computer has to be made in either MSC or MTP mode, see page 10 of the manual.
MSC mode means that a computer will see the player as a removable disk when connected.
It's like exploring the computer detecting the player as an external memory, showing up as a drive letter with about 1 GB of memory.
Before disconnecting the player, always safely remove hardware, the icon in the bottom taskbar on the right.
MTP mode means that a computer has software installed like Windows Media Player 10 and in this software, when started, the player is being recognized as Sansa c140.
Before disconnecting the player, wait for the message that it is allowed to disconnect the device.
How to use Windows Media Player 10 ? See the site of Microsoft:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa c140 MP3 Player
I want to download an album from my computer to my Insignia mp3. When I plug the player into my computer all I get is the charging screen. I want to get the album from media player.Jerry
When the player connects only with the charging display, there are 3 points that need to be checked:
Battery and cable connection
1. Connecting the player to the computer, the charging symbol should start loading; battery "green" or "partly green" indication. The player should respond with "OK to disconnect" = connection established correctly.
For proper charging and connection put the USB cable plug directly to the computer preferred at the back side: not through a hub or card reader.
MSC mode
2. The player is switched to MSC mode. MSC = Mass Storage Class. In this mode the device is seen as a flash drive also called removable disk, that can be accessed using Windows Explorer.
The Hold switch was in hold position on the top side, before connecting to the computer.
Disconnect the player and release the hold switch. Next the player should be in standard MTP mode. MTP = Media Transfer Protocol used for transferring files with media software.
MTP mode
3. The media software on the computer for transferring files is not installed or not working properly. Update or reinstall the media software.
Manual for Insignia NS-DV2G:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
When this didn't help the firmware on the player needs to be reinstalled.
For firmware see the Drivers in the Support tab of the next link:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html
Oct 01, 2009 | Insignia NS-DV2G MP3 Player
I cannot get music to load on to my coby mp3 player
Downloading/Uploading files
1. Connect the player to PC.
2. Open WindowExplorer on PC.
3. Select the file to save and drag-and drop it into the
removable disc icon. You can also transfer file fromthe
player to your PC.
Do not remove the player while it's transferring files.
It might currupt or damage the firmware and or files
on the player. If the player is accidently removed
while transferring and does not work properly,
remove battery for 3 seconds and replace it.
Note:
Disconnecting the Player
After completing the file t ransfer, you must disconnect the
player as following direction:
Double-click on the green arrow in the taskbar on the
bottomright of the window.
When the [Stop a Hardware] message appears, press the
[OK] button and disconnect the USB port.
Dec 02, 2008 | Coby MP-C827 MP3 Player
Ypt9 2gb problem
take out the pilot transferer and do not touch it for a few days and see what happens i have a 8 out of 10 results thank you for reading this goodbye
danigirlb55
Oct 08, 2008 | Samsung YPT9 Digital Media Player
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
YP-T9J Screen stuck on transferring files do not disconnect
Vegggie Boy is mistaken. You should press and hold the red record button while pressing the menu button. The player will reset itself to normal operational mode.
Jun 14, 2008 | Samsung YP-T8 Digital Media Player
Help i have a Samsung YP-T9 and it froze
hold down the menu and play button at the same time to reset, should turn it off, then just turn it back on again
Jun 11, 2008 | Samsung Yepp YP-T9 Digital Media Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
My Screen is stuck on "transferring files...do not disconnect
Hold down the record and the menu button simultaneously... that should restart it. There's a topic about this that has already posted, hope you find the answer here or there.
Sep 25, 2007 | Samsung YPT9 Digital Media Player
Samsung Yepp YP-T9 Digital Media Player Logo
29 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
