Question about Bushnell Voyager 78-9945 Telescope
Altitude dial The pointer on the altitude dial does not rotate with the up and down movement of the telescope's main barrel or tube. It slips. I had this problem with my first telescope and Bushnell replaced it with a new telescope under the warranty provisions. The replacement telescope has exactly the same problem right out of the box.
  • 3,186 Answers
The altitude scale on these small telescope are virtually useless and cannot help you find objects in the sky--
Don't worry about it --- just use the scope and a star chart to find things in the sky. A free monthly star chart that you can download is available here:
Posted on Dec 28, 2008
No laser beam on topcon rlh3c laser level
Take this to a survey/laser repair shop, preferably one that does not charge for estimates.. The laser diodes on the RL-H3C is not serviceable. It requires the lens barrel assembly (or telescope tube unit, i don't remember what they call it in these). It's unreasonably expensive, and will likely be a write off. It may however be the main circuit board, but likely not. Be prepared to replace this unit.
Feb 25, 2014 | Topcon Rlh3c Rotating Laser Level W...
The blower would not shut off, it kept blowing cold air. My repairman came and we saw the silver dial was in the completely upside down position (the 3 pointers were at the top). The pointers were set at...
The dial positioning does not really matter as this is a thermometer of sorts. It is a thermo controlled switch, upon reaching the desired temperature it turns on the blower and upon cool down it shuts off the blower. The dial positioning is not necessarily critical but with him turning it he could have damaged it meaning that instead of registering at say a set 150 degrees it may actually be more than 150 or less than 150 and it will work just the set temperature may be wrong. Confusing isn't it!!
Dec 25, 2010 | Honeywell L4064B2236 Fan/Limit Control...
How to use orbitor 2010 telescope
This is a small reflector style telescope on an Altitude Azimuth mount. There are no specific manuals on the internet; however other manufacturers make the same telscope and they are all assembled and used the same way.
Here is Meade's similar telescope:
The tube is identical.
Dec 11, 2010 | Optics
The finderscope for the Bushnel 78-9930 telescope will not align w/ the telescope. The Azimuth adjustment knob bottoms out before the alignment is achieved. Everything is molded one piece. Besides the...
Obviously the mounting for the finderscope is NOT parallel with the tube-- probably the screw holes were not drilled correctly.
This is one of the reasons why we never recommend Tasco or Bushnell telescopes. They are considered "toy" telescopes and most of them are not suitable for Astronomy.
Return it and buy one of these:
OR re-drill the holes so the finder scope is more parallel with the main tube.
Aug 28, 2010 | Bushnell Voyager 78-9945 Telescope
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
Apr 08, 2010 | Meade ETX-60 AT Telescope
The Azimuth Dial isn't firmly attached cause altitude cannot be fixed to an angle
Most of the small telescopes setting circles really cannot be used to find anything--- just not accurate enough---
Try using a star chart -- and star hopping --- to what you want to see.
A free monthly star chart is available at :
Jan 03, 2009 | Bushnell Voyager 78-9945 Telescope
Celestron nexstar 8 i series alignment trouble
use the rewmote that came with the telescope and go into setup under telescope and push enter when it says calibrate motor
Nov 06, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Thermostat differential on a Bev air ef48-1as
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
Jun 24, 2008 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Bushnell Voyager 78-9945 Telescope Logo
67 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
