Question about Dell Dimension 4600 PC Desktop
Turning the pc on
I have a dell 4600, when i turn on the computer, the power button lights up and the light for the hard drive comes on for about 20 seconds and then goes out. the monitor does not come on so i don't know if the pc is even booting up. I have a working desktop that i put this tower on and it doesn't work. Ca n it be fixed?
  • teratura Dec 26, 2007
    I did change the vga card and the monitor did work and the pc started to boot up, but it said that it had some problem with config/sys. and it also said keyboard failure, what else could be wrong?
    Thanks!
    Sniper:
  • 56 Answers
Try changing your graphic card ( VGA Card ) .. if the problem keeps coming then try the monitor on another computer .. if it works then you have problem with RAM drives
Posted on Dec 25, 2007
  • Baraa Alkazzaz Dec 26, 2007
    looks like your motherboard is having troubles .. if you're using USB keyboard then try using PS2 keyboard ... and for the confing/sys try to restrore your pc to older date
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
I have a Dell Dimension 4600. I press the power button. The left light on the tower turns on amber, the right light comes on for 15 seconds or so then shuts off. The monitor will not come on, but will...
The most likely cause is a failing power supply. Unless you have a tester you will need to buy a replacement. Check the specs and order a suitable replacement. (www.newegg.com is my choice)
If any of this goes past your computer knowledge take your computer to an expert to examine first-hand.
Dec 26, 2010 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 doesn't come on. When i press to on button I get an orange light on the power light ( left hand one ) then nothing happens. can you help
Possibly a faulty power supply?
Faulty Power cable?
Faulty Video Card?
Try replacing each of these in turn , remove all components and try to boot with the basics - 1 stick of memory, no drives, just video
Then add 1 drive
Then add another stick of memory
Keep going till you work out whats stopping it from starting.
Regards
1234s282
Apr 18, 2010 | Dell Dimension 4600 PC Desktop
Computer won't shut off (occasionally)
usually this the indication of Hard driver problem.
this hard drve is on its last lag. it is hardware failure.
get a new Hard Drive and copy everything to the new hard drive. save this one as a backup.
May 22, 2009 | Dell Dimension 4600 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Wont power up
Hi jgeorge76,
I'm sorry to tell you this, but the yellow light means that there is an internal power problem. Usually this problem is a worn-out power supply (the unit at the back of the computer near the top that the power cord plugs into), and it would explain why the computer won't turn on.
If your computer is still under warranty, I suggest you seek help from Dell. If not, don't worry -- a power supply is relatively inexpensive (around $30-40) and not too difficult to replace. You can easily purchase one online and install it yourself. Rest assured that your hard drive and all its contents are safe and intact; you just need to replace the power source.
I hope this helps - please let me know if I can be of any further assistance.
Dec 12, 2008 | Dell Dimension 4600 PC Desktop
Problem with Dell 4600 Dimension Computer
on the computer you will see 4 leds labled A B C D. make sure all are Green. if not there is some issue withe the system.
Jul 04, 2008 | Dell Dimension 4600 PC Desktop
System won't boot
Better you try with a bootable CD, if that works then check for your Hard Disk it might got faulty or crashed.
Feb 04, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
75 people viewed this question
Clive
Clive
Alun Cox
