my friend reformatted my laptop and none of the drivers were on it. we installed the drivers, but the computer does not charge the batter or even have a battery meter on this... is this something built into windows that isnt working properly or is this a seperate driver or program needed...
i guess you have to try another package of windows. the problem is within your operating system. maybe your drivers are not the correct one's, try downloading the real drivers. if this doesn't work, then it becomes a technical problem
Comments:
Oct 11, 2009
- can you specify your laptop model, that way i might be able to help. but on the other hand, can you try and go to the power options then check to see if your
battery is present on the power meter, just to make sure your battery
is working. if its present then try another package of windows.
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude C640 PC Notebook
I have replaced the mobo in my dv6000 and still have the same issue. power sometimes comes on for a...
(More)
I have replaced the mobo in my dv6000 and still have the same issue. power sometimes comes on for a second or two. Power supply is generic but output is pretty close to spec...within .25 vdc. Should I suspect the processor... or was I sold a bad mobo. Will this post wo a processor? Thanks in advance.
The machine wont go further than the swirling circle after logging in. I was told by the tech...
(More)
The machine wont go further than the swirling circle after logging in. I was told by the tech support I would need tomreset to factory settings but then it worked. I dont have disks so will need to transfer to a USB
how do i use my delstar netbook i got this for my daughter and we are use to regular computer and...
(More)
HOW DO I USE MY DELSTAR NETBOOK I GOT THIS FOR MY DAUGHTER AND WE ARE USE TO REGULAR COMPUTER AND THIS IS NOT COMING TO US HOW TO USE IT
