Home | Directed | 3 BUTTN 434MHZ 2/66 CODES REMOTE Remote Con... | Need the code for a phi...
Directed 3 BUTTN 434MHZ 2/66 CODES REMOTE Remote Control
Problem for Directed 3 BUTTN 434MHZ 2/66 CODES REMOTE Remote Control
Need the code for a philips tv fos my magnavox
By pvtedwardsjm on Oct 10, 2009
need the code for a philips tv fos my magnavox remote
Solution #1
posted on Oct 10, 2009
Not Rated)
Dish Fitter
Rank: Guru  Televisions & Videos  Expert
Rating: 87%, 124 votes
Here are the codes for Philips for you Magnavox Remote.
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
Just in case you dont know how to program the remote.
I will guide you through them below.
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the List above Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Hope this has Helps you out, If so Please leave a thumbs up
Cheers
Little Dish Fitter
Was this helpful?
Yes
No
Popular Solutions for Directed 3 BUTTN 434MHZ 2/66
Questions and Unsolved Problems for Directed 3 BUTTN 434MHZ 2/66
Do you recommend Directed 3 BUTTN 434MHZ 2/66 CODES REMOTE Remote Control?
Answer
Answer
I have a GE remote and I need a code for a APEX TV Do u know it?
Answer
i brought an asda universal remote- i have a watson tv and have no idea what the code is, the tv is... (More)
Answer
need find numbers for panasonic tv will you abel to tell me please
Answer
audi a4 1.8t quatro 51 02 registerd remotes loosing codes and wont work can open drivers door on key... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Directed 3 BUTTN 434MHZ 2/66...:
Top Remote Control Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Remote Control Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
